Home > Puma (Tdci) > 2015 110 front brake calipers. |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 535 |
Try Cabmaster
www.cabmasters.com |
13th Jul 2020 8:00pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
LOF do calipers with stainless pistons already fitted DEFENDER 90 TDCI XS,
13th Jul 2020 8:25pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1940 |
Another vote for LOF, plus their disks and pads are great quality 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
13th Jul 2020 8:40pm |
Gladys Member Since: 28 Nov 2015 Location: South Wales Posts: 36 |
Thanks for the suggestions so far. Unfortunately it looks as though they changed the Puma calipers in 2015 for VIN numbers FA onwards to a different part number, LR061253 and LR061254. These are the ones I can’t find, so if anybody has any information about them I would be very grateful.
13th Jul 2020 9:50pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3464 |
I am considering zinc plating my less than shiny calipers. Never done it before, so no idea on the results. I can mask the bore before plating, or just re hone after plating.. not sure which is better.
This way i can apply a heavier, thicker plating that might last longer than OEM/Genuine. The problem is when I will have the time to try it out! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Jul 2020 5:17am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8145 |
Changed what on the calipers in 2015? I bet its just a mpn change, same vented discs and mounting points are they not? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Jul 2020 9:07am |
Yes, you may well be right James, but I would prefer if somebody can confirm it before I waste money on the wrong thing which won’t fit simply because LR (in their infinite wisdom) moved the brake pipe or changed the shape to satisfy some ridiculous late EU requirement. I could mention the traction control with the off switch, but let’s not go there...
There has to be somebody on here who knows if the calipers are identical or different? lrworkshop shows SEB500460 from VIN 6A to EA, then LR061253 from FA. So come on guys and gals, who has more information? |
14th Jul 2020 11:02pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
As long as the caliper is for vented discs it will be fine. Rgds.
Chris |
15th Jul 2020 12:16am |
thats also my understanding Cheers
16th Jul 2020 6:51am |
