Home > Puma (Tdci) > 2015 110 front brake calipers.
Gladys
Wales 2015 Defender 110 Puma 2.2 XS CSW Indus Silver
As everything was very rusty, I replaced the rear calipers and discs with OEM units last year. It was all quite straightforward.
I think the front ones could do with some attention this year. Unfortunately, there don’t seem to be any OEM calipers available for the 2015 model. The genuine ones are of course eye-wateringly expensive. I wouldn’t mind trying to rebuild the original ones, but I don’t want to be stuck without the vehicle if I encounter a problem, so even a pair of pattern ones would do as a stopgap.
Has anybody found alternative units that fit, at a realistic price? There are some listed on eBay but it appears that they are for solid, not vented discs.
Thanks in anticipation.
Post #843541 13th Jul 2020 8:46pm
htb2
Wales
Try Cabmaster
www.cabmasters.com
Post #843544 13th Jul 2020 9:00pm
LR90XS2011
LOF do calipers with stainless pistons already fitted DEFENDER 90 TDCI XS,
Post #843549 13th Jul 2020 9:25pm
bear100
Another vote for LOF, plus their disks and pads are great quality 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #843552 13th Jul 2020 9:40pm
Gladys
Thanks for the suggestions so far. Unfortunately it looks as though they changed the Puma calipers in 2015 for VIN numbers FA onwards to a different part number, LR061253 and LR061254. These are the ones I can’t find, so if anybody has any information about them I would be very grateful.
Post #843557 13th Jul 2020 10:50pm
Dinnu
I am considering zinc plating my less than shiny calipers. Never done it before, so no idea on the results. I can mask the bore before plating, or just re hone after plating.. not sure which is better.
This way i can apply a heavier, thicker plating that might last longer than OEM/Genuine.
The problem is when I will have the time to try it out! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #843564 14th Jul 2020 6:17am
jst
Changed what on the calipers in 2015? I bet its just a mpn change, same vented discs and mounting points are they not? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #843613 14th Jul 2020 10:07am
Gladys
Yes, you may well be right James, but I would prefer if somebody can confirm it before I waste money on the wrong thing which won’t fit simply because LR (in their infinite wisdom) moved the brake pipe or changed the shape to satisfy some ridiculous late EU requirement. I could mention the traction control with the off switch, but let’s not go there...
There has to be somebody on here who knows if the calipers are identical or different?
lrworkshop shows SEB500460 from VIN 6A to EA, then LR061253 from FA.
So come on guys and gals, who has more information?
Post #843803 15th Jul 2020 12:02am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
As long as the caliper is for vented discs it will be fine. Rgds.
Chris
Post #843808 15th Jul 2020 1:16am
jst
thats also my understanding Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #844015 16th Jul 2020 7:51am
