Home > Td5 > Td5 aircon hoses
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Td5 aircon hoses
Is there a difference between rhd and lhd when it comes to the hoses from the condenser to dryer and compressor to condenser?
I am addin a puma bulkhead and it would make more sense for me to plumb the high pressure line on the compressor side of the engine, as well as keep the low pressure line on the same side.
I can adapt the hoses from the dryer to the expansion valve, as well as from the expansion valve to the compressor hose. But i would like to keep the condenser hoses stock if possible. Can't leave well enough alone
Post #842397 7th Jul 2020 6:56pm
Naf
To run Puma bulkhead with TD5 aircon you will need these parts
Defender Aircon Hoses
JUE110330
JUF500010
JUF102250
JUE501020
LR036357
The Puma Hvac connection will need the low side modified.
You then will need to plumb the low side 180 degrees then back to the low pressure side hose. Can't leave well enough alone
Post #843435 13th Jul 2020 7:54am
Zed
Hello mate,
Have you had the truck on the dyno yet? It must be seriously quick.
What is the thinking behind swapping for a Puma bulkhead? WARNING.
Post #843454 13th Jul 2020 10:33am
Naf
The Puma Bulkhead is purely for the aircon to work properly. My last attempt did not work properly.
I made some holes in my radiator last time i took it to 160kph, so i have been waitin on Allisport to send me a new radiator.
In the mean time, i kept over thinkin my problems, and will be coatin the inside of the cab in lizardskin for more sound and heat reflection.
i am six to eight weeks away from a dyno time.
I will post my findings once they are known to me.
Thank you for keepin up with my progress Can't leave well enough alone
Post #843458 13th Jul 2020 10:56am
Zed
Cheers for the update. Look forward to seeing the results.
I'm also waiting on a new radiator from them... WARNING.
Post #843468 13th Jul 2020 12:00pm
