Home > Td5 > Td5 aircon hoses |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
To run Puma bulkhead with TD5 aircon you will need these parts
Defender Aircon Hoses JUE110330 JUF500010 JUF102250 JUE501020 LR036357 The Puma Hvac connection will need the low side modified. You then will need to plumb the low side 180 degrees then back to the low pressure side hose. Can't leave well enough alone |
13th Jul 2020 7:54am |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3294 |
Hello mate,
Have you had the truck on the dyno yet? It must be seriously quick. What is the thinking behind swapping for a Puma bulkhead? WARNING. This post may contain sarcasm. |
13th Jul 2020 10:33am |
The Puma Bulkhead is purely for the aircon to work properly. My last attempt did not work properly.
I made some holes in my radiator last time i took it to 160kph, so i have been waitin on Allisport to send me a new radiator. In the mean time, i kept over thinkin my problems, and will be coatin the inside of the cab in lizardskin for more sound and heat reflection. i am six to eight weeks away from a dyno time. I will post my findings once they are known to me. Thank you for keepin up with my progress Can't leave well enough alone |
13th Jul 2020 10:56am |
Cheers for the update. Look forward to seeing the results.
I'm also waiting on a new radiator from them... WARNING. This post may contain sarcasm. |
13th Jul 2020 12:00pm |
