Home > Tdi > Back |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 |
Now you tell me š
27th Jun 2020 10:01pm |
Definitely needs a clean that one! I realised mine only looks clean because itās got so many new parts....triggers broom. Iāve never cleaned it!
28th Jun 2020 4:24pm |
Iāve finally put the wheels on that I bought from Clemson a few months ago...all looks ok, just need a paint. But that is like buying new shoes with an old suit. Mrs H is blessing a change a colour and a soft top š. I also mentioned the āneedā for two piece doors...
Click image to enlarge |
1st Jul 2020 6:33pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 |
Me too Click image to enlarge The alisport header tank is no longer on, gone back to a original one but is white and not black Sorry i'm late to this thread, but this happened to me with the alternator, it is something you would never think of, it got me stumped at the time as well, glad you got the 90 back now Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
1st Jul 2020 8:36pm |
Funny how we put stuff in thinking great idea and then take it off a while later.... Mine had a treat today, a trip to the local lorry place for a steam clean underneath.
2nd Jul 2020 1:29pm |
Followed by replacement window blocks!! I dug out an early set made to test the tooling set up and they fitted fine.
3rd Jul 2020 7:59am |
Right, the little donkey is still leaking a bit. Where is this coming from? Top right.
Click image to enlarge Also I spotted this pipe is somewhat severed, which I imagine happens during the steam cleaning. What is it? Bottom left of photo.... Click image to enlarge Leaks aside, she is driving very nicely. |
10th Jul 2020 6:43pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 |
I'm not 100% sure I've got my bearings right, looking at those from underneath..
But the corrugated pipe that's split (on the offside of the engine?) looks like it's the air intake pipe, the bit from the drain valve (flap!) up to the air cleaner.... Is that right? This would allow more water spray or vapour up into the filter container. If it's set up OK, then this water will drain towards the front, and out of the drain valve there. But still not a great thing to have a split in that hose so low down. On the oil drip - is that on the nearside? If so, then I think there are a number of places that it could be coming from - the sump seal/gasket; maybe from the crankcase breather to air intake hose connection? (right at the back n/s of the block); rocker cover gasket?; maybe even the crankshaft seal into the bellhousing. Seeing as you've cleaned it, I'd be tempted to see if I could trace it back further to see if you could find a clue to the source? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
10th Jul 2020 9:47pm |
Yes the corrugated pipe does go up to the air box. The drip I will investigate further tomorrow, very annoying after engine out etc. It will get sorted!
10th Jul 2020 10:21pm |
Funnily enough, I was under mine today and found I had a leak in the very same place...!
My first thought was a poor seal at the sump gasket, but shortly afterwards I found what I think is the real culprit. I'd had an engine out/rebuild done too, and the turbo drain hose wasn't sealing well where it joined the adapter to the block. Not a lot of oil, but enough. Probably an unlikely/unusual one really, but I thought I'd mention it. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Jul 2020 8:12pm |
Ah, thank you for that. Iāll mention it to the garage. I had another look today from above and it is right at the back of the block. š¤
11th Jul 2020 8:29pm |
š„ 350 miles in a day, no drama. Obviously the radio decided itās one job was too much about 10 miles in, but apart from that it was all good. I had to stop after about 100 miles because my arse went to sleep- not quite enough space in the pick up to put the seat back...
Very happy, she pulled like a train. I also popped into Harwoods at Edenbridge and they have a 110 XS in Aintree Green coming in....Mrs H has said sheās happy with a 110 as the daily driver so Iām keen to see it.... |
23rd Jul 2020 8:49pm |
Mot passed with no advisories!! Now showing 188k miles.
Iāve been trying to buy an approved used Disco 4. 3 dealerships Iāve been in dialogue with but when you ask basic questions it falls apart. I checked the MOT history on the first and it had advisories so I asked if they had been done. Discs had but front suspension arms hadnāt as āour 165 point check didnāt pick them upā Absolute BS, they werenāt willing to pump Ā£800 in to the car and were waiting for a mug punter not to check. Second was a cracking looking car down in Taunton...with no service history in the first 2 years- not lost or missing, not done! Third was available on the site, worked out a deal only to be told it was sold, but the sales guy I was dealing with wasnāt aware. How difficult is it to buy a well cared for clean D4 HSE and up that isnāt black or white? |
9th Sep 2020 9:18pm |
Headlights wonāt stay on full beam, I need to hold the stalk forward. Is it just a new stalk?
15th Sep 2020 9:18pm |
