Home > Td5 > Which starter motor?
Adammacky
To cut a long story short... I need a new starter motor for my TD5.
Question is which brand is best or most recommended?
Have looked at denso, bearmach, hella, allmakes 4x4 etc. But what do people think?
Kind of need to get it ordered ASAP Shocked
Thanks Thumbs Up
Post #842104 6th Jul 2020 2:21pm
ibexman
Denso is choice of many
Post #842110 6th Jul 2020 3:14pm
excossack
A few choices here
https://www.lrdirect.com/NAD101240-Starter..._https=yes 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #842114 6th Jul 2020 3:24pm
miker
Do you definitely need a new starter motor?
The motor doesn't fail all that often, more likely to be the solenoid contacts. These are easy to fit yourself.
Post #842135 6th Jul 2020 5:14pm
roel
If it doesn't work solenoid contacts as said.
If it turns slow, take it apart and clean the gearbox and pack with new grease. Sounds starnge but that will make a lot off difference. Roel
2003 90 Td5 (2009-now)
Post #842147 6th Jul 2020 6:27pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
What are the symptoms?
New solenoid contacts as has been said.
Worst bit is the PITA bolt....
Post #842154 6th Jul 2020 7:10pm
Adammacky
Solenoids already been replaced and, wires checked and everywhere cleaned up so had the garage i use check everything over and hes sure it needs a new starter Shocked
Post #842159 6th Jul 2020 7:39pm
miker
In that case I probably would stick with denso
Post #842161 6th Jul 2020 7:39pm
jst
Dense for me Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #842187 6th Jul 2020 9:19pm
Adammacky
As i thought everyone would say i have gone ahead and gone for denso Thumbs Up
Post #842210 6th Jul 2020 10:35pm
roel
Get the old one and check the gearbox I bet it turns difficult. Roel
Post #842244 7th Jul 2020 7:48am
