Home > Puma (Tdci) > wabco ABS |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 |
Ouch ! 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
6th Jul 2020 10:58am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
top tip !!
6th Jul 2020 2:16pm |
Craig-C Member Since: 25 Aug 2017 Location: Staffs Posts: 40 |
Just done the same job myself on my TD5. Worked a treat. My motor was also full of rust.
It is difficult to access but can be done on a TD5 by removing the inlet grill and ducting, wheel arch and loosening the brake pedal box. My Puma is a none ABS spec. Maybe the cost is just due to availability. FFRR TDV8 sold PUMA 90 :0[==]0: 90 TD5 CSW XS MX5 (NC) BMW 320 BMW 1200 GS Adventure SUZUKI HAYABUSA |
6th Jul 2020 5:46pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 928 |
As above, purely down to availability, all discovery 2s came with abs/traction control and were sold in their thousands, plus lots being scrapped due to chassis rot which is a shame really.
Useful to know though as my td5 has abs |
6th Jul 2020 5:58pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 317 |
Do you know if this works? Have you tested it with individual wheels with lost traction? It concerns me that not matching could cause the electronics of the ABS to release the wrong brake. |
6th Jul 2020 6:04pm |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 75 |
yes, abs and TC work on the correct wheels. managed to get it cross axled on a local lane near me for a bit of a play.
Wabco only have one part number for these pumps. Landrover just plumbed them differently for the disco. New pump arrived yesterday so have a bit of a dilemma. fit it or keep it as a good spare... |
7th Jul 2020 6:49am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
I imagine that the ECU simply tells the modulator which brake line to pulse or release, and the mapping of wheel to output is in the ECU. If the ECU says modulate line 1, the modulator with do just that.
It's a handy tip to know that these are interchangeable*. * But I am still glad I don't have ABS/TC on my Defender, it would just be one more thing to go wrong. |
7th Jul 2020 7:47am |
youre not wrong Lonewolf! It's not a fun job getting that lump out of the tiny little hole they found to put it in
7th Jul 2020 9:16am |
