![]() | Home > Wheels & Tyres > Dynabeads in rear tyres? |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
My cooper discoverers have done about 30k now and have recently developed a 60mph ish wobble. Would people recommend rebalancing, small beads through the valve or unseating them and putting big beads in?
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 530 ![]() |
Break the bead and put large beads in is what I would do 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
Did you sort this Col? It's not clear from their website if the stated quantities are per wheel or per vehicle? Did you put 6oz in each wheel? EDIT - Just spoke to them, it's per wheel ![]() Cheers. Rgds. Chris |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
I couldn’t get them to overcome the imbalance from where the tyres were fitted by an incompetent fitter! Took them to someone that knows what they are doing and they are balanced perfectly without the need for beads.
Same for 285/75/16 tyres ![]() |
