Home > Puma (Tdci) > Central Locking
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Central Locking
Does anyone know how to disable central locking as I can't find a fuse for it. My problem is when I've been traveling on wet roads and creat alot of spray or have used a jet wash this is effecting the central locking. One of the door switches thinks the open is open when infact it is shut. I can't lock the doors with the remote as this sets the alarm off, and if I try and lock the doors with the key the central locking unlocks all the doors again. I'm wanting to lock the doors manually by disabling the central locking over night until I have chance to get to the dealers in the morning. I've looked in the manual and fuse box but can't find central locking fuse
Post #83810 10th Aug 2011 8:51pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Re: Central Locking
Prob a bit late,if you remove rubber between drivers door and A post, you can undo central locking plug,this sould disable central locking.
If not remove passenger too, then under the drivers seat there is a small White plug (two wires) that works the rear doors undo that.
Cheers Ash
Post #83836 10th Aug 2011 11:54pm
pjw4233
Cheers Ash, managed to disable central locking with your advice
Post #84006 12th Aug 2011 8:27am
Landyash
Your welcome Thumbs Up
Post #84167 13th Aug 2011 8:16am
