Landyash
pjw4233 wrote:Does anyone know how to disable central locking as I can't find a fuse for it. My problem is when I've been traveling on wet roads and creat alot of spray or have used a jet wash this is effecting the central locking. One of the door switches thinks the open is open when infact it is shut. I can't lock the doors with the remote as this sets the alarm off, and if I try and lock the doors with the key the central locking unlocks all the doors again. I'm wanting to lock the doors manually by disabling the central locking over night until I have chance to get to the dealers in the morning. I've looked in the manual and fuse box but can't find central locking fuse
Prob a bit late,if you remove rubber between drivers door and A post, you can undo central locking plug,this sould disable central locking.
If not remove passenger too, then under the drivers seat there is a small White plug (two wires) that works the rear doors undo that.
Cheers Ash
10th Aug 2011 11:54pm |
Landyash
Your welcome
13th Aug 2011 8:16am |
