Home > Technical > Central Locking problem |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1036 |
The central locking has stopped working on one door - driver's side, 2nd row.
I assume it's a broken wire in the rubber tube that leads to the door. Before I start ripping it apart, are there any other likely locations for the problem? |
21st Jun 2019 6:00am |
Thanks - I'm busy this weekend, but will take a look by the end of the month.
21st Jun 2019 8:04am |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 |
I have had issues with mine as the doors in the back are not used much and needed the old grease cleaning off then re-lubing. Of course in this case you could hear the solenoid trying to work.
When the front failed it was the wire in the door as it went through the little black tube and no solenoid sound. 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
21st Jun 2019 9:36am |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 135 |
I had same problem. Thought it was the wires as they’ve gone before but on inspection they were OK
I popped off the door cards and sprayed all linkages with white grease. As Swallock noted, back doors were the most seized cos of lack of use. Been fine since. 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
21st Jun 2019 4:13pm |
I can't believe it's taken a whole year for me to get round to fixing this!
Could this be the problem? Click image to enlarge |
27th Jun 2020 10:44am |
Er, yes. Darren
27th Jun 2020 11:40am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 |
you can get a loom upgrade kit I think
27th Jun 2020 5:40pm |
