Home > Technical > Central Locking problem
AMBxx
The central locking has stopped working on one door - driver's side, 2nd row.
I assume it's a broken wire in the rubber tube that leads to the door.
Before I start ripping it apart, are there any other likely locations for the problem?
Post #778362 21st Jun 2019 6:00am
BigRuss
Both second row doors on mine have done this and both times it was a broken wire in the harness.
Other option is that it could be the solenoid in the door or the wear in the cam but unlikely Russell
2011MY 110 XS USW Black
Post #778364 21st Jun 2019 6:24am
AMBxx
Thanks - I'm busy this weekend, but will take a look by the end of the month.
Post #778373 21st Jun 2019 8:04am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I have had issues with mine as the doors in the back are not used much and needed the old grease cleaning off then re-lubing. Of course in this case you could hear the solenoid trying to work.
When the front failed it was the wire in the door as it went through the little black tube and no solenoid sound. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #778382 21st Jun 2019 9:36am
DG123
I had same problem. Thought it was the wires as they’ve gone before but on inspection they were OK
I popped off the door cards and sprayed all linkages with white grease. As Swallock noted, back doors were the most seized cos of lack of use. Been fine since. 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #778424 21st Jun 2019 4:13pm
AMBxx
I can't believe it's taken a whole year for me to get round to fixing this!
Could this be the problem? Shocked Shocked
Post #840018 27th Jun 2020 10:44am
Er, yes. Darren
Post #840025 27th Jun 2020 11:40am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
you can get a loom upgrade kit I think
Post #840083 27th Jun 2020 5:40pm
