Home > Tdi > 52mm Gauges
Page 1 of 3 123>
frenchy
52mm Gauges
Well I thought that this was going to be easy...……
I am going to install a Mud Console in the 300tdi.
New radio across the bottom - OK
Bank of Carling Switches above the radio - OK
I want a couple of 52mm gauges across the top (volt meter, Rev counter, EGT monitor)
I want all the gauges to look like a match to the standard dash gauges (black face, white markings, white or red needles and white backlight) similar to the voltmeter and overall panel look below...….
The VDO range of gauges look ideal but I cant find an EGT gauge in their line up, or indeed a Rev counter.
Fourby do an EGT gauge but it can't be fitted in the EGR blanking plate as the probe is too short Shocked
Stack do an EGT gauge but its expensive and I have no idea if its probe would fit.
There are some Rev counters on Ebay, but the ones that LOOK like a good match say "NOT SUITABLE FOR LANDROVERS"???????
see below......
https://www.ebay.co.uk/itm/R-SPEC-DIESEL-5...SwAh1dyVq~
Can Somebody please point me in the right direction...…. 2000 D2 TD5 - ahhh bless
2006 D3 - no longer with us and sadly missed
1997 300tdi d90 - now with electrics that work!
- now with a brand new custom made soft top fitted
…...…...............….new chassis now all fixed and driving like new
2010 D4 alas no more, but a lovely colour (Nara)
2016 D4 battery magically fixed with NOCO charger
Post #839766 25th Jun 2020 11:12pm
Oldsalt
United Kingdom 1995 Defender 90 300 Tdi CSW Portofino Red
Saw this one on ebay, seems to be universal fit, not sure why the one you found not suitable for land rover.
Price not too bad so may be worth a gamble.
https://www.ebay.co.uk/itm/52mm-0-6000-RPM...890.l49292
Post #839774 26th Jun 2020 5:30am
jonny
VDO do make a rev counter, but you will have to hunt hard to find it for a decent price:
https://www.merlinmotorsport.co.uk/s/instr...ion-gauges
Likewise EGT (Pyrometer):
https://www.ebay.co.uk/itm/PYROMETER-GAUGE...1499148226
I ended up getting the rev counter from the US as it worked out considerably cheaper.
They are a pretty close match to standard gauges, the illumination is slightly different and the needles are red not orange but other than that they don't look out of place.
Post #839790 26th Jun 2020 7:55am
hxk494
I recently had a similar dilemma, though fitting in a Mud mini-pod dash mount. Ended up with a Stack EGT gauge - can confirm probe fits but needed a slight bend. Can take some photos later if you like.
It was expensive but no issues with fitting or operation. 1996 300Tdi Defender 110
Post #839811 26th Jun 2020 8:49am
Martin
Site Admin
Also have a look on https://vdo-webshop.nl
e.g. https://vdo-webshop.nl/en/temperature-gaug...22637.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #839846 26th Jun 2020 12:00pm
frenchy
Yes any photos of the installation would be great if not too much troulbe Thumbs Up 2000 D2 TD5 - ahhh bless
Post #839982 26th Jun 2020 11:39pm
Alex1976
I did my dash with gauges all from Stack as that was the only supplier that seemed to be able to offer all the matching set and that worked with the 300tdi. Really like the style of them too, the 270* sweep of the gauges for accuracy and a nice led backlight display.
I went for speedo, EGT, water temp, fuel and clock.
Post #840017 27th Jun 2020 10:33am
frenchy
Fourby do this rev counter...…..
https://fourby.co.uk/epages/950004277.sf/en_GB/?ObjectID=48769021
I think I'll mount this in the dash - close enough match the the original instruments (black / orange / white) - and move the clock to the Mud console.
If I go for Stack instuments, I might have to upgrade to a stack Stack clock as well (but £93 Shocked )
https://www.merlinmotorsport.co.uk/p/stack...t3317-3367 2000 D2 TD5 - ahhh bless
Post #840036 27th Jun 2020 1:27pm
frenchy
Alex - love the look of your cabin - all clean, matching, and 'factory look' Cool 2000 D2 TD5 - ahhh bless
Post #840038 27th Jun 2020 1:31pm
Alex1976
Cheers Frenchy - I was trying to keep it all looking ‘factory’ or at least uniform Thumbs Up
Here’s a couple more pics that show it better.
Post #840111 27th Jun 2020 8:20pm
Pickles
What about a real quality English gauge,.."SMITHS"?
Pickles.
Post #840129 27th Jun 2020 9:50pm
Jon w
Wales 1991 Defender 90 200 Tdi HT Epsom Green
https://www.ebay.co.uk/itm/221181060375
What about that?
Do seem to call them a pyrometer
Post #840215 28th Jun 2020 12:16pm
frenchy
Alex - is that a Raptor dash?? - I like it all sprayed black Cool
Piclkes - I love Smiths / Jeager speedo from the series 2 - if it was a Series vehicle maybe, but the defender has that 80s / 90s look and I am looking to match the original instruments. 2000 D2 TD5 - ahhh bless
Post #840361 29th Jun 2020 12:03am
frenchy
So, here's the plan...….
Main Instrument Binnacle -
Original speedo / Fuel / Temp plus New Tacho for fourby (saves £60 over the VDO unit and a close -ish match to originals)
Centre Mud Console
New EGY (PYROMETER!!) / New Clock / New Voltmeter - all from stack and (for me Embarassed ) eye wateringly expensive but will all match each other and a close enough overall match to the main instruments
Got a new Kenwood radio now as well - just need to work out how to set the multi changing LED colours to match the rest of the instruments (I'll have to read the destruction book Big Cry )
Post #840363 29th Jun 2020 12:18am
Alex1976
Yep Raptor centre console and a raptor dash with the raptor metal binnacle housing too. It makes it so solid compared to the original plastic jobby
Post #840364 29th Jun 2020 12:28am
Page 1 of 3 123>
