![]() | Home > Wheels & Tyres > The Wolf steel wheel appreciation thread |
No, the PCD (pitch circle diameter) is the dimension that determines the locations of the holes in the wheel.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
Apologies my last message crossed over with your explanation.
Yep, sorry about that last message should have said offset is -35 not PCD in my last message
No problem. The offset is the distance of the centreline of the wheel relative to the hub. The larger the number, the further inboard the wheel will be and visa versa.
Standard LR alloys have an offset of 33mm. Wolf wheels and direct copies have an offset of 20.6mm but because they're only 6.5" wide rather than 7" for alloys, they're not directly comparable without a bit of maths. From memory when I changed mine, the outside of the wheel ended up 6mm further out than the original alloys. Wolf wheels with zero offset will be 20.6mm further out than standard ones and about 27mm further out than standard alloys. Wheels being further out can help with a reduced turning circle if the steering stops are adjusted to take advantage of the extra clearance. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks for that, very clear explanation,I just wasn’t that sure.
As an aside, I see 4x4 ovelander are doing and 8” steel wheel with a zero offset. Obviously a different wheel but still interesting to see. |
astroarcadia Member Since: 12 Jun 2020 Location: Gloucestershire Posts: 49 ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
That looks just great
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Well, they are at least on. Paint needed.
So Astroarcadia, what size of tyres are on your wheels, they look a right nice combo
Buzzsaw Member Since: 15 Aug 2012 Location: Swindon Posts: 61 ![]() ![]() ![]() |
Finally went for it
![]() ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Look great
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
That looks great with the white roof. Blue and white is one of the best combinations IMHO. Darren
swediscodefender Member Since: 22 Jul 2020 Location: Stockholm Posts: 2 ![]() ![]() ![]() |
![]() Click image to enlarge Hi! I just got my first Defender - 110 CrewCab 2008. Since the previous owner just slammed on whatever he could purchase cheap it doesn’t have a cohesive look in my opinion....and I started to strip down the “additions”. I am planning for a dark grey hood, a full black checker plate kit and single steps.... but most of all I want those Wolf wheels on!! Unfortunately I am divided when it comes to the colour.... either white or matching santorini black... I couldn’t find any ref pics in the thread of Black 110dcpu with white roof & white Wolfs... Has anybody got a pic?? |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
White because of the roof.
