Home > Maintenance & Modifications > Replacing bonnet release cable
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
I’ve snapped my bonnet release cable near to the bonnet the catch but unfortunately there isn’t enough cable left on the end to move it along a bit. I see on my Puma that the cable is in a couple of parts. Has anybody replaced the front part of the cable (from just behind the air box forward)? I’m wondering if it’s a difficult job? I can see one securing clip near the air box but not sure if there are more under the front wing?
Post #839430 24th Jun 2020 4:10pm
donmacn
Is this on a Puma or something else? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #839446 24th Jun 2020 5:23pm
sgreenham
On a 2010 Puma
Post #839449 24th Jun 2020 5:33pm
donmacn
Ah. Apologies then. It was the way you said " I see on my Puma....." I read that as if you might have been comparing your Puma to something else.
I could say that on the earlier cars, there's an inner and outer cable, and replacing the inner cable would be quite straightforward. I'm afraid I'm not in the least familiar with the Puma-era vehicles.
Again, on the earlier ones, replacing the cable would be easier with the OS headlight removed. Maybe the case here, but I better stop until someone comes along who knows what they're talking about. Whistle Donald
in the past..
Post #839455 24th Jun 2020 5:46pm
DSC-off
I was advised to use a genuine LR cable when my TD5 one snapped. "You won't want to do it again in a few months time..." Thumbs Up
Post #839498 24th Jun 2020 8:06pm
sgreenham
Ah I didn’t even think about removing the headlight, good shout.
Post #839539 24th Jun 2020 10:38pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Just to reinvigorate this thread, has anyone a step by step guide on how to replace the bonnet catch end on the cable on a Puma? My bonnet pops open always now and on inspection, the head of the 7mm bolt that you adjust the cable with has sheered off somehow, and the cable is slipping.
I have a genuine replacement cable and new 7mm bolt and olive. After extensive research, Icant find anything on how to replace this item on a Puma era Defender.
Thanks for any help with this everyone.
Ken
 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #993226 19th May 2023 1:01am
Baytown
All sorted, and the two piece cable makes life easier!
You can access it from the Rt
wing panel cut out and then just thread the new cable out via the Rt headlight.
I removed my grill to be able to totally remove the bonnet lock assembly panel so I could drill out the failed 7mm bolt.
All good now and working as it should be.
Post #993251 19th May 2023 9:11am
TexasRover
That's a mighty bumper. I take it that is for the kangaroos? I do like the way it offsets the headlights.
Post #993262 19th May 2023 11:38am
Baytown
Hi Texas;
Ha, thanks here in Australia they are a very common modification. We call them a ‘Bull Bar’ and used due to the wildlife on the road which includes cattle, camel, emu etc as well as the ubiquitous kangaroo.There’s a very real chance of hitting a critter when out of town on country roads. Also, you can nose your vehicle into a tree etc when winching which really makes heavy recovery so much easier sometimes.
Driving light and UHF antenna, and sand flag mounts as well as seed net-wading blind are a must for us as well if travel remote.
They are a must now days due to the risk of writing your Defender off with panel damage.👍
Post #993333 19th May 2023 8:24pm
