Home > Puma (Tdci) > Fox Shocks Advice
Peregrine_White
United Kingdom 2008 Defender 90 Puma 2.4 SW Keswick Green
Fox Shocks Advice
I am planning to fit a set of fox shocks to my 90 that are arriving in the next few days. has anyone fitted them and know if I need to reuse/replace the small locating washers. Part Number RYF50020?
Post #839303 24th Jun 2020 7:49am
bear100
The shocks come with their own washers and bushes but i presume you mean the washer in the turret? i reused mine they were like new, i would contemplate fitting new shock turrets, i wish i had done this to mine at the time.
Great shocks though, you will need an extra hand you help push the turret down to secure in place the fox have a lot more resistance to the OEM
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #839310 24th Jun 2020 7:56am
Peregrine_White
Thanks for the tip bear! I am fitting all new hardware from gwyn lewis including turrets, spring seats, retaining plates etc. I was more referring to the smaller washers with the lip that centralise the shock in the turrets and base. I can't tell from the images of the shocks as to whether they come with them.
Post #839314 24th Jun 2020 8:07am
bear100
They come with the upper and lower washers, i reused mine in the turret (wish i had done the turrets at the time, anyway a set on order for a future fit) mine didn't have them on the lower end just the top, i don't think it will make a great deal of difference if you added them though
Post #839324 24th Jun 2020 8:27am
red-scirocco
Id recommend ditching the poly bushes and fitting OEM rubber bushings. 2006 (56) 110 Td5 Double Cab
Instagram @110_td5
Post #839358 24th Jun 2020 11:16am
trailbear
Can I ask the reason for ditching the Polybushes please?
David
Post #839450 24th Jun 2020 5:34pm
Likeomg
I really liked the supplied bushes,
Also get some YRM stainless washers for the rear extra bling factor. broke my heart reusing the old washers... got YRm now
https://yrmit.co.uk/product/316-stainless-...r-classic/
Post #839451 24th Jun 2020 5:34pm
Co1
I couldn’t get in with the supplies bushes, so keep your old one case. Mine were too stiff and actually impacted articulation. My tears also didn’t come with the top washer and I had to put the dirty old ones one. Unlike LikeOMG mine are still on 🙁
Post #839460 24th Jun 2020 6:01pm
red-scirocco
Machine mine down to 20mm, still swapped them out for rubber bushings on the front axle with the correct washers. The rolling comfort and plushness is not there with the polyurethane bushes supplied.
still using the supplied rear bushes atm, but going to try out Genuine LR ones soon. 2006 (56) 110 Td5 Double Cab
Instagram @110_td5
Post #839463 24th Jun 2020 6:25pm
trailbear
Ah, I see, thanks
David
Post #839499 24th Jun 2020 8:18pm
Avelingporter
Sorry for the old thread restart, but the title is correct.
Just about to install Alive comfort springs and fox shocks. I have one pair of rubber gaiters. Do you need gaiters on front and back? Or do I fit on the fronts now, as they are a PIA to fit later, and then add to the rears later as that’s quite easy?
Do you even need them on the fronts? I am assuming on the rears they are needed as the crud that gets chucked up by the front tyres will hit the rear shocks.
I’ve looked on here at various threads and photos of other peoples installs do not seem to have a common solution.
Post #964548 10th Sep 2022 7:50am
keith
I have 🦊 front and rear. They do not come with gaiters. GET SOME. The rears were replaced under warranty for leaking out all the oil due to seal damage caused by stones. Rears only required.
Post #964553 10th Sep 2022 8:48am
Avelingporter
Thanks Keith. Rears only then.
Post #964555 10th Sep 2022 9:19am
keith
(Pro comp ribbed protection) from Gwyn Lewis. Ziptie top and bottom.
No I didn’t know he sold condoms either Laughing
Post #964557 10th Sep 2022 9:24am
