Home > Maintenance & Modifications > Defender Security Bonnet Hinges
Page 2 of 2 <12
Hernia
United Kingdom 2015 Defender 90 Puma 2.2 CSW Aintree Green
Have you spoken to them directly? The windscreen brackets were showing out of stock when I wanted them, so I emailed and it turned out they were just putting the kits together, within a couple of days they were back in stock.
Post #838763 21st Jun 2020 4:45pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I‘m very happy with these
https://www.designdevelopmenteng.co.uk/sto...p188776023
High quality and easy to fit. You can‘t remove the bolt with bonnet closed; it‘s not a „security“ bolt such as torx pin. Also the nuts from underneath the bonnet are not shear nuts.
(these are the standard black not matte)
Post #838779 21st Jun 2020 5:29pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I have swapped all of my external stuff for stainless security bolts - couple of different types mixed on every fitting.
Anything that makes the scum move onto somewhere else that is easier has to be worth it. Rgds.
Chris
Post #838787 21st Jun 2020 6:29pm
trailbear
Gents
Thanks for the advice and ideas.
I particularly like the mixing up of the fittings and securings, I hadn’t considered that......such a simple solution!
I like those bonnet hinges, they are pretty much identical to the originals.
Need to consider which ones to chose now🤔
Post #838898 22nd Jun 2020 2:05pm
discomog
I've done the same as Pacha and used a mix of different screw heads. Anyway of delaying the scumbags has got to be good. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #838918 22nd Jun 2020 3:06pm
X4SKP
Hello trailbear
In my opinion the value of these bonnet security hinges is almost completely down to the quality of the
of the security bolt holding the 'barrel' in position, this assuming the rest of the product is made
from reasonably tough material does improve the standard arrangements, so is worth adding.
As covered... the bulkhead hinge part is stud / welded into position and so can for all reasonable scenarios
not be considered the weak link, the standard bonnet element of the hinge is as good as its fixings,
these can be upgraded to 'unique' types... the crazy bit is that Land rover never corrected the 'bonnet off'
when vertical arrangement, hence the aftermarket work-arounds. Its worth noting that the standard hinge
contains the 'bulk head element' and 'rubber sleeve' well... its just the 'hook it on' that will do... doesn't do.
When I got my latest Defender I looked at the then few security hinges on the market at the time (2013)
and inclined to play around I went a different route.
I wont detail just how these are fixed, other than to say it took a lot of effort. I'm happy enough with the
result, I like the fact also I'm almost certainly the only one, this approach was probably considered and rejected
by those who have made a security hinge, because of the install requirements. I fitted these after I applied
Dinitrol to the bonnet where it's easy lift off characteristics were appreciated (once).
 SKIP
Post #838925 22nd Jun 2020 3:39pm
Oldowner
I purchased a set of these purely to stop the bonnet rattling as their bush and pin system is superior to any other hinge out there.
Post #839005 22nd Jun 2020 7:15pm
macfrank
Thumbs Up for closing that gap this way.
With security hinges you could even close it permanently, in theory. In practise I can't think of a neat solution (because I have no clue of welding and painting).
Post #839008 22nd Jun 2020 7:32pm
trailbear
Skip
That is some fancy piece of fabrication work which I would have to say is completely beyond my current skill set.
I shouldn’t imagine that will come off anytime soon!
David
Post #839015 22nd Jun 2020 8:09pm
X4SKP
Post #839022 22nd Jun 2020 8:27pm
Pacha
Skip - Carbon Fibre Bonnet? Rgds.
Chris
Post #839033 22nd Jun 2020 9:14pm
X4SKP
Hello Pacha
No... unless Vinyl counts... Question
(Roof, Wheel Arches, Front Bumper, and Steering Guard also)
 SKIP
Post #839085 23rd Jun 2020 9:16am
Argee
I've been in touch with Gore, they've been making parts for ventilators instead so we'll let em off maybe.
Post #839125 23rd Jun 2020 12:24pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Hopefully rear door hinges for them. My van's well ventilated!
But joking apart, good on them.
Post #839130 23rd Jun 2020 12:30pm
Page 2 of 2 <12
