Home > Td5 > Drivers electric window
ibexman
Con you replace just the motor or is it a complete regulator motor combined
Post #838766 21st Jun 2020 4:55pm
Sturdaa
United Kingdom 2005 Defender 90 Td5 CSW Alveston Red
Fairly sure it’s a combined piece. If you’re on a budget look for one from the passenger side of a Saxo, it’s the same part
Post #838812 21st Jun 2020 9:37pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Take out the entire assembly, remove the motor, clean it up. be extremely careful when disassembling noting where the tiny parts and rubber seal order goes together.
usually the bottom of the motor would have collected water and the bearing rusted causing it to get stuck.
Spray plenty of WD40 or equivalent into the motor housing and leave over night. drain excess WD40 and clean up with kitchen towel.
Apply a generous amount of grease onto both the bearings and light amount to the carbon brushes.
Carefully reassemble and it should work.
test it before you put the assembly back into the door and mount the glass.
Sure, it's a lot of work, but this is what i've done a few times to resurrect them when they jam up. The defender has migrated, leaving the owner behind.
Post #839372 24th Jun 2020 1:05pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Have you 100% tested the wiring that goes to the motor? It goes brittle in the sheath that goes between the door and the bulkhead. Thats where mine always fail... Insta: @thebenjordan4x4
Post #839588 25th Jun 2020 8:45am
