![]() | Home > Technical > Intercooler pipe routing |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8181 ![]() ![]() ![]() |
That is correct looking intercooler pipe and positioning looks right too. Does air filter box rotate? Is that not a td (19j) air filter housing? Cheers
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 949 ![]() ![]() |
There is not enough room to connect the inlet pipe to the air filter without it squashing up against the intercooler pipe. Feels like I need another 20mm of space.
Air filter housing is this: ![]() Click image to enlarge ![]() Click image to enlarge I think that is the correct one but the mounting cage does seem to have been moved and not sure of the angle. |
Can you attach pipe with mounting clips undone? Ie does it rotate? Yes that is correct filter housing. Are intercooler pipes in correct orientation? Cheers
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2711 ![]() ![]() |
You seem to be missing the elbow on the airbox intake. This would move the flexi hose joint further back and away from the lower intercooler pipe.
Item 11 below ![]() Click image to enlarge |
Turns out the previous owner had just done a rubbish job of installing the pipe. Loosened all the jubilee clips and rotated it and it fits a treat now, plenty of room for the inlet pipe.
Will still need the elbow which I will order. Thanks for the help ![]() |
