Home > Technical > Intercooler pipe routing |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
That is correct looking intercooler pipe and positioning looks right too. Does air filter box rotate? Is that not a td (19j) air filter housing? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Jun 2020 10:58am |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 937 |
There is not enough room to connect the inlet pipe to the air filter without it squashing up against the intercooler pipe. Feels like I need another 20mm of space.
Air filter housing is this: Click image to enlarge Click image to enlarge I think that is the correct one but the mounting cage does seem to have been moved and not sure of the angle. |
20th Jun 2020 11:43am |
Can you attach pipe with mounting clips undone? Ie does it rotate? Yes that is correct filter housing. Are intercooler pipes in correct orientation? Cheers
20th Jun 2020 10:00pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2683 |
You seem to be missing the elbow on the airbox intake. This would move the flexi hose joint further back and away from the lower intercooler pipe.
Item 11 below Click image to enlarge |
20th Jun 2020 10:05pm |
Turns out the previous owner had just done a rubbish job of installing the pipe. Loosened all the jubilee clips and rotated it and it fits a treat now, plenty of room for the inlet pipe.
Will still need the elbow which I will order. Thanks for the help |
24th Jun 2020 10:09pm |
