Home > Puma (Tdci) > Cant get MudUK reverse LED to work |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3498 |
Have you swapped the polarity of the cables?
16th Jun 2020 5:27pm |
jbullis Member Since: 28 Apr 2013 Location: Jonesborough, TN Posts: 24 |
I'll try popping out the pins and swap the cable to see if it works. I would hate to think two were wired wrong?
16th Jun 2020 5:29pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Worth trying this, as your reverse light plug (on the vehicle harness) may be wired back to front. Or the socket on the lamp may be wired in the wrong pins. Or post some pics of which wire is where on the plug and on the socket and I'll check what they should be. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
16th Jun 2020 5:33pm |
Click image to enlarge Thanks for the quick reply’s. I swapped the wires and it lit right up. |
16th Jun 2020 6:27pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
LED's are polarity sensitive. Rgds.
Chris |
16th Jun 2020 7:48pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Had a similar problem on some plough lights I recently bought for my tractor. Someone on the Chinese production line couldn't tell the difference between a red wire and a black wire or decided to swap them around for sheer devilment. Defender 90XS SW
17th Jun 2020 7:31am |
