Home > Maintenance & Modifications > General Electrical Header Crimps |
Behind centre fascia
14th Jun 2020 6:26pm |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 |
Yep that's where it is. I just need some crimps to terminate the wiring in the spare hole. 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
14th Jun 2020 6:28pm |
give PauMc PM or martin
https://forums.lr4x4.com/topic/106429-wiring-header-joints/ or Sumitomo 090 Terminals. F https://www.automotiveconnectors.com/AC69-15000106-T.html |
14th Jun 2020 6:45pm |
Your a star many thanks. Looking at the Satellite fuse box I've also got to add in the crimp that also forms a 3 way busbar for fuses 33 /34/ 35. I don't suppose you know if this is available?
Click image to enlarge 2003 Defender TD5 Hardtop (current - work in progress) 2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
14th Jun 2020 7:04pm |
