Home > Maintenance & Modifications > General Electrical Header Crimps
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I'm in the process of fitting heated seats / elec windows to my basic TD5 90 and trying to keep the wiring as factory as possible. To fit the Ignition Relay(R211) I've got to make a connection to the positive header (C0285 term 4). Does anyone know what wiring crimps I need so I can terminate the wire in the terminal hole please? (edited to clarify)
Many thanks
Paul
 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #837182 14th Jun 2020 6:12pm
dorsetsmith
Behind centre fascia
Post #837184 14th Jun 2020 6:26pm
landybear
Yep that's where it is. I just need some crimps to terminate the wiring in the spare hole. 2003 Defender TD5 Hardtop (current - work in progress)
Post #837185 14th Jun 2020 6:28pm
dorsetsmith
Post #837193 14th Jun 2020 6:45pm
landybear
Your a star many thanks. Looking at the Satellite fuse box I've also got to add in the crimp that also forms a 3 way busbar for fuses 33 /34/ 35. I don't suppose you know if this is available?
Post #837202 14th Jun 2020 7:04pm
