Interesting day today,
Drove the Buggsy to work so I could lend my mate some tools The lightweight went out on a military vehicle run with the missus (now guernsey is easing lockdown) The lightweight decided it didn’t like oil in the sump so threw it all out Buggsy recovered the lightweight home Missed the Land Rover coffee meet as we swapped tyres over onto Jasmin Got Jasmin down the off-road event and threw her around the course Removed the snorkel top off Jasmin curtesy of a low branch I didn’t notice Now off for a curry in the Fiona (D3) So everything’s been out and used today bar Maggie as she’s still in bits ![]() Pics will follow later ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 938 ![]() ![]() |
Ladder, work lights and sorted out the wiring fitting the raptor dash console.
![]() Click image to enlarge ![]() Click image to enlarge |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Clean
frenchy Member Since: 05 Feb 2012 Location: Liverpool Posts: 133 ![]() |
After 100miles in the 300Tdi I thought she deserved some TLC.
Treated her to new air filter, oil filter, engine oil change and G'box oil change and PS fluid. She repaid me by allowing most of these fluids, old and new, to coat all front suspension / axle / gearbox cross member, the floor, and me. This is despite knowing all of the above would happen and taking precautions to prevent them ![]() 2006 D3 - no longer with us and sadly missed 1997 300tdi d90 - now with electrics that work! - now with a brand new custom made soft top fitted …...…...............….new chassis now all fixed and driving like new 2010 D4 alas no more, but a lovely colour (Nara) 2016 D4 battery magically fixed with NOCO charger |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 514 ![]() ![]() ![]() |
Inflated all 4 tyres as sitting on the rims, pushed it outside, swept garage and pushed it back in
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3790 ![]() ![]() |
Drove my Puma for the first time in over 2 months....
Collected my work chair.....from work ![]() ![]() ![]() |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 ![]() ![]() |
![]() Click image to enlarge MOT time. |
Double post
Wow - a commercial place with a pit...I thought H&S had called time on them a good few years ago?
Tr90 Member Since: 06 Jan 2020 Location: Essex Posts: 135 ![]() ![]() ![]() |
Been a good ( long ) weekend working on Wilbur.
Painted the wing mirror arms, mudflap brackets, windscreen wipers and towbar all courtesy of Halfords paint department. Pretty good actually. Despite masking as much as possible still got some overspray on the paintwork. Discovered that brake and clutch cleaner works wonders to get it off! And the original paint has stayed on - bonus. Ended up cutting the bolts off for the mudflap brakes as they were bolted with a nut that you can't get to without citing the subframe. Not doing that! Also fitted new folding side steps and finished this afternoon off by fitting a new rear step. Took about 2 hours longer than needed due to impossible to use hex rivnuts. I say impossible as the step is too heavy to hold in place whilst you bolt it all up. In the end used a scrap of metal and bolted that on first to expand the rivnut in the hexagonal hole. Then attached the step. Cheap Britpart sh*t as when the step is folded the arms catch the bolt heads and have already scrapped the paint. Should have known better. Anyway. Done now and very pleased with result. Windscreen fitting tomorrow. Not got the balls to do that myself so off to Auto Glass. I'm supplying the seal. Then maybe time for some new tyres before the MOT. Lockdown has been expensive. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1945 ![]() ![]() ![]() |
Front genuine springs and new Fox shocks on the front yesterday, a lot worse than the rear to do!! 6 scrapped knuckles!
![]() But what a difference it has made, transformed the ride immensely i mean night and day! that good ![]() uprated rear anti roll bar next ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
csw110 Member Since: 17 Dec 2012 Location: sheffield Posts: 57 ![]() ![]() |
![]() Click image to enlarge New tyres and anti roll bars on my sons 110 , the green one, he has been busy with the arrival of new baby boy ! 😎Took mine for a run, only done 90 miles since the end of February. |
Love the early one ten, a guy i know is currently restoring one on a galv. Had from new
