![]() | Home > Td5 > ABS/ Traction Control Problems |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 964 ![]() ![]() ![]() |
Get is scanned and see what it says. In the absence of a scan tool... Make sure your ABS sensors on the wheels are well seated. They can back out sightly.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2196 ![]() ![]() |
Pull the fuse to reset it.
If it comes back on its a fault likely a damaged/broken sensor. As above check all are properly seated. Instagram @defender_ventures Empire Tuning - Agent |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1833 ![]() ![]() ![]() |
As above, plus a loose wheel bearing, dodgy connections etc.
Friends Disco used to do it if you adjusted the seat............ ![]() |
rustyredwreck Member Since: 16 Jan 2020 Location: Oxfordshire Posts: 24 ![]() ![]() ![]() |
Pulled the fuse and replaced - still showing as a fault.
I'll be donning overalls and having some fun tomorrow. Thanks for the suggestions. Neil |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2980 ![]() ![]() |
The trouble is, ABS rarely kicks in on a Defender driven normally, even in the wet.
So the shuttle valve in the ABS unit can stick. Mine did the same, get it reset then find a piece of grass or gravel and get the ABS to kick in a few times. After that it will most likely be OK. Try to “use” the ABS occasionally, getting the near side wheels on gravel/mud/grass usually does it. Mines been fine since. Obviously this doesn’t always work and you may have an actual fault, but it’s worth a try. Also l think you need to reset it with a diagnostic tool once the warning lights are on. |
to switch abs off you have to tap the brake pedal 10 times in a quick succession, I will become active again automatically above 15 km/hr?
You don't deactivate it very easy by accident. So I am sure that didn't happen. Like what is said before check your sensors or the shuttle valve. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Really? i never saw that in my owners manual? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
There are lots off options not in the manual.
On some cars you can switch the seatbelt beep off by pushing the seatbelt in 10 times in very quickly. I.e. Ford Focus and mondeo some years around 2005 I believe. It also works in a Disco 3 pre 2007 I don't know about the later ones. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
That wont help. You need diagnostics to tell you whats gone wrong. 9/10 times there wont be a physicaly issue withthe sensor. ABS can be hard to turn on but TC is very easy Instagram @defender_ventures Empire Tuning - Agent |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Not an answer, but a question. Do all Td5s have ABS? If so I certainly wasn’t aware mine had. Likewise with TC - do they all have it and how would I know?
No. Only XS Defenders and mid - high spec D2s.
If it has ABS it has TC Instagram @defender_ventures Empire Tuning - Agent |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 932 ![]() ![]() ![]() |
Mine has ABS and tc, it's not an xs. It was optional on all variants and standard on xs.
It will have an ECU under the bonnet and abs tc lights on dash that should illuminate on startup, abs goes off after few seconds, Tc lamp should extinguish once driving over 5mph. |
Fairly rare though! I think the option was around £1800! Instagram @defender_ventures
This is true!
