Home > Tdi > 200 tdi radiator replacement
mini Anaconda
I am going to need to replace my radiator sooner or later and need a bit of advice on which one to buy. Most of them seem to have plastic ends tanks which I guess are probably not so good?
I also see that Bearmach list one with brass tanks at about twice the price, would that be better?
With regards to the oil cooler connections, are they all the same? I think my rad (and engine) is out of a Discovery form 1992 or thereabouts.
Many thanks. BORG - Bucks & Oxon 4x4 Response Group
Post #830911 13th May 2020 3:56pm
donmacn
One of the suggestions i got when I asked this same question was to go for a recore. Mine 300tdi was well shot - lots of the fins were gone and some of the coolant pipes were completely unsupported, but it did have the metal end tanks so was able to be rebuilt.
When the guy measured it, he said he could also get a bigger core into the same space, so i went for that. I think it was a little more expensive than buying a new one, but not that much.
I asked the question on here, so a search should find it.
Edit - dug it out - here's the thread https://www.defender2.net/forum/topic58753...t=radiator Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #830920 13th May 2020 5:41pm
Procta
my dad just went to a local Radiator company and they had one the shelf. Thumbs Up
Give them a bell,
https://www.adrad.co.uk/ Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #833203 24th May 2020 10:40pm
Mo Murphy
If the one fitted at the moment is the original brass version, then get it recorded. That is the gold standard.
50 Shades of Pennine Grey
Post #833232 25th May 2020 7:12am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
exactly what i did. If i remember right original is 2 core and i went for 3 cores. No overheating at all, works very well and i,ve hammered my 200tdi pulling 3t up massive hills, but i guess massive is subjective.
Post #833274 25th May 2020 11:36am
mini Anaconda
Thanks for the replies.
In the end I ordered a Allmakes one from JGS4x4 for a very good price. It fitted just fine and seems do to a very good job, after a 250 mile trip of mixed driving it kept the engine cool and an improvement on the old one.
I have kept the original to be re-cored if needed in the future. BORG - Bucks & Oxon 4x4 Response Group
Post #836105 9th Jun 2020 11:02am
Procta
how long did yours take to bleed? I think my dads needs to be bleed like, it went to temp on tick over no bother. But i think it needs a good run. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #836904 13th Jun 2020 12:19am
mini Anaconda
After filling the rad and expansion bottle I took a hose off the heater matrix and filled through the hose until all air was expelled. I have found in the past this is the best way to remove any air from the system. I don't think that leaving it ticking over it would ever get warm enough.
In the past after a long run, while it never got hot, the engine would smell quite warm and the rad was quite hot. Probably have the opposite problem with it running to cool now. BORG - Bucks & Oxon 4x4 Response Group
Post #837133 14th Jun 2020 1:56pm
Slideywindows
Mini Anaconda, totally OT but I hear your Series Two has now moved up to near me, in South Cambs.
If this is true, I might meet it at the local pub meet - when we are allowed to go to pubs again.
Post #837138 14th Jun 2020 2:35pm
mini Anaconda
That is correct Charles. Send me a picture if you see it. Big Cry BORG - Bucks & Oxon 4x4 Response Group
Post #837223 14th Jun 2020 8:37pm
Slideywindows
Will do! Thumbs Up
(PS. Clearly the Land Rover "bush telegraph" is still working well. Laughing )
Post #837311 15th Jun 2020 11:20am
JOW240725
Love a bit of land rover stalking! Laughing James
Instagram @suffolk_rovers
Post #837329 15th Jun 2020 1:19pm
Procta
I will keep this in mind, my dad decided to bleed it through the rad top, he said some air had come out of the system, laugh was he said it was fine, and it didn't need a bleed Rolling Eyes What a fool he is at times! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #839246 23rd Jun 2020 8:34pm
Eppilihp
Switzerland
Re: 200 tdi radiator replacement
Many thanks.
I have the same problem - and ordered the Bearmach one with brass tanks. Their technical advisor told me I need the adaptor BTP1823U to match the oil line fittings. Well, it turned out that the BTP1823 does not accept these adaptors and they offered me to return the radiator and suggested I should order the cheap radiator with plastic end tanks...
Hence my question, is there really no adaptor that would fit this radiator and accepts the cone style oil fittings, such as NTC3858 for example?
This is what I need:
Could it be that these are still the old oil lines from the original 19J? Could I simply swap them to have the matching thread for BTP1823?
And if not, which reasonably priced radiator with metal end tanks could you suggest?
cheers
Philippe
Post #883736 7th Feb 2021 11:01am
Dinnu
Aren’t all modern cars with an aluminum radiator and plastic headers? They seem to last pretty well there.
I bought one of these rads for my 19J, but have not fitted it yet, so cannot say how bad or good they are. But what I plan doing in mine is to etch prime it and paint it flat black, both for cosmetic and protection. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #883741 7th Feb 2021 11:18am
