![]() | Home > Puma (Tdci) > Reverse switch working but not in reverse |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
Had this with my tdci. Fitted new switch. All ok.
Rumblingroad Member Since: 08 Jun 2020 Location: Cornwall Posts: 5 ![]() ![]() ![]() |
Thanks Andy, will get a new switch ordered and hope that’s it then and is just worn.
Cheers for the reply |
Me too. Failure of this switch seems to be relatively common, unfortunately. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
I had a similar issue with mine, which turned out to be because the switch wasn't fully screwed in to the gearbox. Tightening it up (about 4 turns) fixed the problem.
All fixed new switch, didn’t notice the one in was a ford switch by previous owner which is shorter than LR.
Thanks for the help |
