Home > Maintenance & Modifications > Steering lock movement? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
There will always be quite a bit of slack when the steering lock is engaged. If it was really tight you would never be able to release it!
Steve 02' 110 TD5 Double Cab Rebuild Thread |
2nd Jun 2020 2:36pm |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 168 |
Good point! But it does feel like i could ‘force’ it further opposed coming to a solid stop within a given range of movement.
Guess I need to compare to another of a similar age to see if it’s the same as mine. |
2nd Jun 2020 3:17pm |
What you are feeling is probably the resistance of the tyres on the ground to the steering. If you are bothered try jacking the front axle up and trying again.
2nd Jun 2020 3:31pm |
