Home > Maintenance & Modifications > 1/2” ratchet set recommendations
Page 2 of 2 <12
discomog
Like Swine and Small I still have my AF and Whitworth socket sets from the 1960's, all Britool and are still in use. Had to buy a metric socket set in recent years and went for Halfords.
As suggested above I think I would just buy a new ratchet and replace any worn sockets, don't see the point in buying a complete set if most of your existing ones are still serviceable. If you're not rounding off nuts or taking the skin off your knuckles then they're plenty good enough. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #834400 31st May 2020 10:42am
Co1
Agreed. I’ll just go for the ratchet.
Post #834407 31st May 2020 11:30am
Are you sockets 6 or 12 point?
I'd consider going for a set to compliment what you have, or even a flank drive or deep set. I've generally found buying these in a set is way cheaper than buying them individually.
And get those original ones cleaned up! Wink
Post #834508 1st Jun 2020 7:02am
Co1
12 point supercat. And funny you should say that, they are soaking in degreaser at the moment!
Post #834515 1st Jun 2020 7:42am
discomog
I'm in the process of renovating a 50 year old tractor - I'm sure you can imagine the state of some of the fastenings. If a hexagon socket and strongbar or an impact socket can't shift them then some heat or an angle grinder usually does the trick but there are times when it's unsafe to use heat or inaccessible for a grinder. I've thought about investing in some twist sockets to removed damaged nuts - question is does anybody use them and are they a worthwhile investment? Defender 90XS SW
Morgan Plus 8
Post #834556 1st Jun 2020 11:29am
Co1
I’ve had mixed success with them, I wouldn’t go out of my way to buy a set. If you can weld I find it super handy to clean up the knackered bolt head a weld a good bolt to it then drive it out using the good bolt head.
Post #834559 1st Jun 2020 11:41am
Kevantlin
I really like the Teng stuff, easy tray system to build your set over the years.
Post #834563 1st Jun 2020 11:45am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I have a mixture of Halfords and Clarke professional sockets, both have performed well.
Snapped the head on my Halfords 1/2in knuckle bar, they replaced it no questions asked.
I also have a 1/2in and 3/4 elora set which I bought for very little from a retired engineer- the quality of the sockets and ratchet are fantastic and have already lasted 1 working lifetime- I expect they will probably do another!
Chris
Post #834586 1st Jun 2020 1:50pm
The Crab Botherer
United Kingdom 2001 Defender 90 Td5 ST Nato Green
I've got a mix of Teng and snapon blupoint neither of which have given me trouble, i still have the remains of a 60yr old gedore set which seems indestructable!
Post #834587 1st Jun 2020 1:59pm
Bluest
I've recently bought some Facom stuff which seems nice. Not had it long though 2007 110 TDCi Station Wagon XS
Post #834589 1st Jun 2020 2:05pm
sako243
@Co1 - I'd take the ratchet into Halfords and see what they say. I've not had to replace a ratchet but a few friends have replaced them and breaker bars (which are specifically excluded). The breaker bars they got free after being told "try not to bend this one, we're not supposed to replace them".
I've taken stuff back and my socket set is the best part of 20 years old, the guys in the back didn't need the receipt because of the font they knew it was back in the day when everything was lifetime guarantee.
Are you referring to the Irwin bolt removers? I've had a mixture of success, it varies between "I'm sure it's not going to work on that nut after all there's nothing left" to works really really well. The chap who introduced them to me said the key thing is to ensure that the socket is seated really well. One good whack with a lump hammer, if you have to hit it again then you've lost it.
Mind you I've always found red lubricating stuff helps really well Whistle. Went to undo a couple of M24 bolts on something a month or so ago and after a little bit of a fight they sheared. Oh well it was being broken anyway so didn't matter, but realised half hour later that I might have made a slight oopsie in that it was tightening the nut rather than undoing it Embarassed.
 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #834598 1st Jun 2020 2:46pm
James130
Don’t know about you but my 1988 Defender seems to be made with a clever mix of both metric and imperial fixings.
The spanners and sockets I bought handily fit both, and are made by Metrinch.
I’ve had them years and no breakages yet.
Worth a look.
I’ve also get a very old set of Halfords Professional which have also been great, and sometimes they have a really good sale on.
Cheers - James.
Post #834840 2nd Jun 2020 7:15pm
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
Clarke's and deltec for me no problems with either except the 10mm seem to grow legs Embarassed WHAT COULD POSSIBLY GO WRONG
My sky lantern petition
http://chng.it/HJXmZC47
Post #834841 2nd Jun 2020 7:18pm
Ian80
halfords stuff is good. when it is on sale, or you know someone with a trade card, then you can get it at a good price
Post #835485 6th Jun 2020 1:38pm
DG123
Laughing Laughing
Same here, just bought a couple more as have been pushing my luck with a 13/32AF flat drive Whistle 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #835490 6th Jun 2020 1:51pm
Page 2 of 2 <12
