Home > Wheels & Tyres > Spare wheel mounting plate
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Does anyone have, or could get, the measurements for the spare wheel on a 300 TDi rear door. I've got a mantec spare wheel carrier which has a plate that gets mounted in the same place as the original carrier, but I've binned my old door! Banging Head Any help much appreciated! Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #83095 4th Aug 2011 6:23pm
Tazz
Which measurements precisely are you looking for? The holes for the bolts which hold the plate on, or the distance of the plate from the door edge and window?
tazz
Post #83308 7th Aug 2011 11:37am
Maverick
Both really, just so I can get a good idea of the position of the plate and the holes. Don't want to drill my brand new door to find out its in the wrong place! Laughing Ben
Post #83324 7th Aug 2011 3:17pm
Tazz
On mine, which is a 2004 110 with a Mantec carrier the hole positions are
Top left = 10 cms below window rubber & 33cm from LH edge of door
Top right = 36cm to right of Top left hole & 21.2cm from RH edge of door
Second row is 8.5cm below top row
bottom row is 29.5cm above bottom edge of door.
I would however check elsewhere as well, as on the Mantec site the carriers for pre-2002 model has a slightly different part number.
Tazz
Post #83354 7th Aug 2011 7:50pm
Maverick
Thanks mate, I'll bolt it all on and check! Thumbs Up Ben
Post #83358 7th Aug 2011 8:54pm
