Home > For Sale & Wanted > [Wanted] Bike 🚴♂️ rack wanted.... |
Riksbar Member Since: 29 Sep 2013 Location: North Posts: 20 |
I’ve got a used one of these
https://www.ebay.co.uk/itm/222005768143 You could have it for £50 collected but I don’t know what the postage would be and it would be a massive pain in the rear to package. I’m in Burnley, Lancashire. |
23rd May 2020 2:07pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
When it says overhang is 187 mm what exactly does that mean, my spare wheel on the 90 sticks out from the back door by 280 mm but I am sure my spare wheel is the same size as most 90's?
JD 2008 TDCi 2.4 XS CSW |
26th May 2020 1:29pm |
Also will it fit on this tow bar ? It looks great, ideal for me...
JD Click image to enlarge 2008 TDCi 2.4 XS CSW |
26th May 2020 1:41pm |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 |
Measure from the mounting surface on you drop plate to the outer edge of the spare tyre. Mine is 165mm with the NAS rear step, so the column clears the tyre by 22mm. Click image to enlarge
Probably not then - if a standard tyre is 235mm wide. |
26th May 2020 1:53pm |
So what size is your spare wheel if that bar fits? Or does your tow bar arrangement stick out a lot from the crossmember?
26th May 2020 2:18pm |
The drop plate on the NAS step sticks out 5" from the crossmember. Sorry I didn't actually notice how far this protrudes from the rear crossmember - it would make an expensive bike carrier if you didn't already have one!
The rear tyre is a standard 235/80R16 and overhangs the rear door by 295mm. |
26th May 2020 2:33pm |
Ah OK, that explains it, I guess that's never going to fit mine then, my plate is about 1cm proud of the crossmember
26th May 2020 2:40pm |
