Home > Expedition & Overland > Table for the Rear Door
buckers19
1993 Defender 90 300 Tdi CSW Barolo Black
I’m searching for a fold down table for the rear door and came across the front runner one but it’s made specially for jeeps. However, I’ve seen a few people bodge it to fit on the defender door but cannot seem to work out how because of it’s length, it would seem to be too long to fit between the interior door handle and the end of the door.
So...can anyone report on how they got it to fit or are there any recommendations as to alternatives?
https://www.frontrunneroutfitters.com/en/u...table.html Instagram.com/mattbuckley19
Post #830934 13th May 2020 6:31pm
bear100
Watching this one, I know exactly what you mean and in the same boat myself.
I would prefer a shelf to go on the side but don't want to drill and add brackets 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #830940 13th May 2020 6:46pm
Sulisuli
https://www.defender2.net/forum/topic51267.html
This may help Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #830948 13th May 2020 7:11pm
Bluest
Interested in this. I’d love a table like the Frontrunner one that fits properly and neatly on a Puma. All the ones I’ve seen look a bit Heath Robinson in their attachment. 2007 110 TDCi Station Wagon XS
Post #830949 13th May 2020 7:12pm
ak615
Mobile storage systems do one, not cheap though
https://www.mobilestoragesystems.net/colle...r-defender
Post #830950 13th May 2020 7:13pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I’ve got the Front Runner table ready to fit to my rear door once I’ve done the restoration.
My rear door has a flat piece of checker plate on with a piece also over the rear wiper.
With the table spaced off the door far enough to clear the wiper box it just fits, if I remember right it does cover the door handle very slightly but not enough to cause any problems operating it.
If I get a chance tomorrow I’ll take a photo. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #830961 13th May 2020 7:52pm
keith
Surely must be easy enough to make a nice wooden one yourself?
Keith
Post #830970 13th May 2020 9:05pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
I’ve got one on my 110 so it does fit but I have a full chequer plate panel and no rear wiper. I mounted it by using longer wheel carrier bolts and drilling straight through the back. This is the only pic I could find, not great but if you zoom in you can just about see it.
Post #831007 14th May 2020 8:24am
db950
As Whirly says, it does physically fit but you’d have to make your own brackets depending on which rear door trim you have fitted.
Few pics from this morning with it set up on some clamps!
I’ll need 60mm spacers behind mine so it clears the wiper box.
Post #831010 14th May 2020 8:48am
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I use a drop down shelf from MobileStorage Systems (although I can't see it on their site now) attached to a chequer plate door trim from Devon 4x4. You can see it in the attached photo. The interior doesn't look like this now, but the shelf has served me well for many years. The one from MSS that, I believe, ak615 was referring to is actually their cooker housing for mounting a gas cooker on the back door - not ideal as a simple table.
Sorry, best picture I have to hand at the moment, but you get the idea.
The best ones, I think, are from Ex-Tec. Not cheap, mind
https://shop.ex-tec.de/de/innenausbau-inte...natur.html
Tony
Post #831013 14th May 2020 9:29am
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
They are nice, had our same time as we had the top done..
Post #831044 14th May 2020 12:54pm
donmacn
I got one of these on ebay recently at a lot cheaper than the new price.
I think it's meant to give the option of a small table - but it's an either/or thing - you can't have both at the same time.
The table folds down first, with the stove still folded up against the door. Then you can bring the stove down if you want, but at that stage it takes up the same space.
I'm assuming this is how it's designed to work, but when I got it, the table and stove had been fixed together which just didn't seem to make sense, so some fettling managed to separate them.
This stove/table combo needs four bolts attached to the back door cover that it can then slot/hang onto. Reading this thread made me realise I could probably make up something else like the front runner one to attach to those same bolts first and then to unfold to the side, or even rustle up a slide-out board that would attach to the bottom of the stove itself. Interesting. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #831047 14th May 2020 1:15pm
AlexCW
United Kingdom 2013 Defender 110 Puma 2.2 HT Galway Green
What door card and table is this? Looks very smart Alex
2013 2.2 TDCi Puma Hard Top
https://www.defender2.net/forum/topic72473.html
Post #837195 14th Jun 2020 6:51pm
db950
Tony
Think it’s this one I’ve quoted from the post above... 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #837331 15th Jun 2020 1:30pm
AlexCW
Perfect, thank you.
Should’ve read it better I suppose! Alex
Post #837332 15th Jun 2020 1:32pm
