Home > Technical > Technical drawing of a dixon bate ? |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
Anybody have a drawing with dimensions of a the above?
Planning to create my own slider for a new bike rack, my exisitng one utilized a old slider i welded my new rack too, it did end up fairly heavy and hard to attach, anyway im at work now and going to make a new slider out of stainless 12mm thick. to go with my stainless 2 part rack. Plan to have it dual pin to limit the rattling. |
11th May 2020 12:43am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
11th May 2020 8:52am |
perfect, thanks so if i made my slider plate 150mm wide i'd be good. |
12th May 2020 12:35am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Likeomg
Here is just the Slider with dimensions. I have the CAD PDF from DB so if you want that PM your email address to me. Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
12th May 2020 1:17pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
If for just a push bike rake, isn't 12mm thick a bit over the top? Just trying to save some weight. James
12th May 2020 3:38pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2649 |
Will be future proofed if an e-bike is purchased..
12th May 2020 8:03pm |
Perfect, will do thanks @jow, it’s going to be in 2 parts, my current one I just welded to a existing Dixon bate slider and it’s very heavy... to the point it’s too awkward and heavy to use. This new one will be in the style of a north shore rack Click image to enlarge |
12th May 2020 8:23pm |
This was my v1 attempt.
I can stand on it without any flex so maybe over engineered slightly... Click image to enlarge Click image to enlarge |
12th May 2020 8:34pm |
KelvinB Member Since: 17 May 2018 Location: Crickhowell Posts: 24 |
Nice job, but did you say the magic words?
13th May 2020 5:57am |
