Home > Technical > Technical drawing of a dixon bate ?
Likeomg
Anybody have a drawing with dimensions of a the above?
Planning to create my own slider for a new bike rack, my exisitng one utilized a old slider i welded my new rack too, it did end up fairly heavy and hard to attach,
anyway im at work now and going to make a new slider out of stainless 12mm thick. to go with my stainless 2 part rack.
Plan to have it dual pin to limit the rattling.
Post #830403 11th May 2020 12:43am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Post #830430 11th May 2020 8:52am
Likeomg
Venomator wrote:
perfect, thanks so if i made my slider plate 150mm wide i'd be good.
Post #830581 12th May 2020 12:35am
sako243
Re: Technical drawing of a dixon bate ?
Doesn't help Laughing - ask how I know. Admittedly that is with 3.5t behind it through hilly Welsh terrain. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #830682 12th May 2020 12:32pm
X4SKP
Hello Likeomg
Here is just the Slider with dimensions.
I have the CAD PDF from DB so if you want that PM your email address to me.
 SKIP
Post #830689 12th May 2020 1:17pm
JOW240725
If for just a push bike rake, isn't 12mm thick a bit over the top? Just trying to save some weight. Thumbs Up James
Instagram @suffolk_rovers
Post #830707 12th May 2020 3:38pm
markb110
Will be future proofed if an e-bike is purchased.. Thumbs Up
Post #830776 12th May 2020 8:03pm
Likeomg
X4SKP wrote:
Hello Likeomg
Perfect, will do thanks
@jow, it’s going to be in 2 parts, my current one I just welded to a existing Dixon bate slider and it’s very heavy... to the point it’s too awkward and heavy to use.
This new one will be in the style of a north shore rack
Post #830782 12th May 2020 8:23pm
Likeomg
This was my v1 attempt.
I can stand on it without any flex so maybe over engineered slightly...
Post #830784 12th May 2020 8:34pm
KelvinB
Wales 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Nice job, but did you say the magic words?
Post #830805 13th May 2020 5:57am
