Home > Maintenance & Modifications > Defender 110 load bay carpeting and sound deadening
Trevor110
United Kingdom 2005 Defender 110 Td5 CSW Barolo Black
Hi all,
I don’t have carpeting in the 110 Country from under the back seats backward. I’m fairly sure it used to have some (there’s a retainer trim at the back door), but it disappeared at some point in its life.
I want to sound proof the back (eventually the whole thing) and carpet it all, including up on the inner whee arch boxing. Thinking thicker on the bed and thinner on the wheel arches maybe.
I’m ideally looking to avoid the mega expensive sound kits and was thinking 2mm butyl sheeting. Anyone made their own? Worthwhile or a false economy?
Also, any tips on carpeting it, could stump up for a full OEM set, but it’s eye watering.
Hoping I can benefit from someone’s experience here!
Thanks a lot
Tom
Post #830212 10th May 2020 9:43am
bankz5152
FatMat Mega Mat is the best value for money (at least I was last I checked!) Theh also do cheaper options
Covering that loadspace makes one of the biggest differences when soundproofing a Defender.
As the rear is a generally a very simple square shape its easy enough to line it yourself with some "van" carpet off ebay. Just use a heavy duty high temp spray glue. Instagram @defender_ventures
Empire Tuning - Agent
Post #830219 10th May 2020 9:54am
Trevor110
Thanks Bankz. Willl take a loot.
T
Post #830412 11th May 2020 6:58am
