Home > Maintenance & Modifications > Roof repairs |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
How big are the holes? It isn't very clear from the pictures.
The easiest way would be to put a sealed rivet in each hole (if the holes are small) or something like a roofing bolt if they are bogger, with sealant, then paint over them. The heads would be visible, but I would think not very conspicuous. If you want a near-invisible repair, you'll have to feather the holes, bond a backing panel to the inside, then fill, sand and paint. There was a recent thread discussing options for filling rivet holes from chequer plate on a bonnet on the forum, when similar techniques were discussed. |
7th May 2020 2:40pm |
MarcusM Member Since: 29 Jan 2020 Location: Nottingham Posts: 101 |
Hi Blackwolf- thanks so much for your reply- sounds like I may have to put a backing plate on as I think they are quite large. Never used rivets as yet as I’m new but seems like it’s something I need to get my head around.
Have attached some more photos with a pen for scale! Will also look up that other thread- thanks for your help Click image to enlarge Click image to enlarge Keswick green 2007 Defender 90 TD5 |
7th May 2020 5:41pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 739 |
Looks like there was a beacon mounted on the roof.
7th May 2020 6:06pm |
hi did think that GCC - no idea on its previous life- to be honest since removing the black wrap I’m quite liking the white roof!
7th May 2020 6:11pm |
Chugga90 Member Since: 07 Sep 2014 Location: Bucks Posts: 208 |
Would fitting one of those self watering features - a sunroof, be a solution, one hole instead of six?
Just an idea. |
7th May 2020 6:41pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3675 |
Have done similar recently, albeit not on the roof. It’s not as hard as I thought. Topic here:
https://www.defender2.net/forum/topic72208.html |
8th May 2020 11:31am |
Chugga - not a bad idea - you’ve got me looking now!
Thanks for this Co1 will take a look Keswick green 2007 Defender 90 TD5 |
8th May 2020 8:17pm |
