Home > Tdi > Braking system upgrade/overhaul |
domm786 Member Since: 14 May 2016 Location: Scotland Posts: 56 |
i dont know too much about the TD5 parts (i own 300tdi 90) but i assume they are similar
https://www.lrworkshop.com/diagrams/land-r...?year=2002 look at the above link and that will supply the part numbers for your car. Couple of tips when doing the job: - To remove the calipers its 13mm bi-hex socket DO NOT USE ANYTHING ELSE. they are in very tight and probably rusted. out of the 4 calipers i took off i had 2 bolts sheer off - the bolts which secure the discs to the hub are 14mm spline-head (which is very almost bi-hex so you will get away with using a bi-hex socket) - buy new caliper bolts and also new disc to hub bolts as they cost pennies and you will thank yourself later. - use the correct locktite on the bolts and torque them up to the correct setting. - this should be obvious but dont use copperslip or any other anti sieze on the bolts otherwise they risk unwinding themselves. I think these are the parts numbers you are looking for but double check these: Vented Discs 110/130 - LR017952 Front Brake Caliper Vented - RH - SEB500460 Front Brake Caliper Vented - LH - SEB500470 Caliper Bolt - SYP500090 (2 of these per caliper) Disc to Hub Bolt - UYG500030 Torque Settings: Disc to Hub - 72nm (use loctite 270) Caliper to Housing - 82nm you are very lucky to have a mechanic mate who will lend you his workshop and his tools |
15th Jul 2019 10:24pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2212 |
New rear disc fitted today. The top calliper bolt caused grief as the socket length bumped the spring. Upon removal of hub there are 6, 11mm nuts to undo first. They hold on this fin type plate. Why is it there.?
Click image to enlarge |
3rd May 2020 7:45pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Fin type is to pulse for the ABS sensor
3rd May 2020 7:55pm |
Ahhhh I see
Thanks for that info. Keith |
3rd May 2020 8:34pm |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 |
ABS! ON A DEFENDER!!
3rd May 2020 8:38pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
its also used as speed sensor on the Defender 50th... maybe others,
4th May 2020 6:12am |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Is this upgrade just as simple for pre 300tdi Defenders - i.e a straight swap for 110/130 front calipers?
5th May 2020 12:44am |
