Home > Maintenance & Modifications > Brake Mods/Upgrades
Page 2 of 3 <123>
keith
The 2 calliper bolts, ( 13mm 12point ) at the rear. The upper one is impossible to get out because of the spring. What size socket is needed please. ( Length )
Keith
Post #829086 3rd May 2020 7:30pm
jst
I use 3/8th ratchet and short 13mm socket to loosen it then take ratchet off and turn socket by hand. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829089 3rd May 2020 7:45pm
jst
Do you run out of bite due to heat or run out of servo assistance with repeat braking?
If the former than you need means of disapting the heat better.
If latter then you need a bigger servo.
Do brakes start off with good bite? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829092 3rd May 2020 7:49pm
bear100
Ive just fitted the LOF powerspec kit on mine (the rears going in tomorrow) and the quality is fantastic, there are really good reviews around with them and they are priced very well too 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #829100 3rd May 2020 8:06pm
Mdm
assuming your callipers are in good order then new vented drilled / grooved discs all round with a higher temp brake pad will improve things. more so when the brakes are warm
Downsides are noise when cold sometimes plus faster pad wear.
you can upgrade to higher temp brake fluid which helps as well but isn't cheap.
bigger callipers up front and bigger discs work better but are far from cheap.
swapping the servo is possible as well but again a lot of work and cost
if you compare to fast road cars then i tend to keep std callipers and upgrade the fluid and pads and whn the discs wear out fit better quality and spec ones
Post #829104 3rd May 2020 8:11pm
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
I recently swapped my original 1995 calipers for 4 pot vented 110 calipers and a nice new set of 2 pot calipers on the back. Due to lockdown I haven’t been able to bed them in properly yet, but it’s made a huge difference.
It may be because the inside pots on the calipers weren’t even causing the pads to contact the disks 😅
Post #829110 3rd May 2020 8:35pm
keith
Fitting new discs today and oops... Censored Evil or Very Mad
Threaded the brake pipe nipple.
Post #829113 3rd May 2020 8:39pm
jst
Now that is a pain. Personally I would make up a new copper one from t piece. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829301 4th May 2020 8:48pm
keith
Yep one piece new. Super tit I am. Shouldn't have taken the pipe out at all. Should've kept it and calliper together and simply tied it up outa the way. Hindsight is a great thing eh. I don't have the tools or parts so it's off to the repair garage, oh and a bill Big Cry
Keith
Post #829307 4th May 2020 9:12pm
jst
buy them online prob £30 for kit and some pipe reuse one fitting and buy one new one. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829763 7th May 2020 8:10pm
Mdm
110 brake upgrade
Post #829881 8th May 2020 12:46pm
Hufflepuff
Hello Keith,
For the unenlightened amongst us (me), what went wrong there? For the life of me I'm not seeing the problem in the photo, no doubt it will be obvious once you point it out. 2005 Td5 90 XS
1989 V8 110 CSW
Post #829920 8th May 2020 4:15pm
Stripped the thread on the nipple, by the looks of it.
Post #829924 8th May 2020 4:42pm
Hufflepuff
Ah ok thanks Blackwolf, the thread looked OK to me from about 5mm up in the image. 2005 Td5 90 XS
1989 V8 110 CSW
Post #829929 8th May 2020 5:24pm
keith
Sugerpuff.
The nipple threads all the way down but as you see I've stripped it. ( the smooth shiny with no threads )
Amateur Rolling Eyes it shouldn't have been out at all but simply kept in the calliper and tied up outa the way. I got lucky As I could easily have stripped the calliper thread also and then need needed new one also.
So be careful.
Keith
Post #829954 8th May 2020 7:03pm
Page 2 of 3 <123>
