Home > Maintenance & Modifications > Brake fluid change how to do? |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
If you’re feeling lazy you can suck the fluid in the reservoir out with a syringe and replace. It’s obviously not going to bleed out any air, but if your brakes are performing OK it will at least remove a decent amount of old fluid that could have absorbed water. 2014 Keswick Utility 2.2
2nd May 2020 8:28am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Got diagnostics & ABS? You can pressure bleed it.
Start with the furthest caliper from the master and work forward. Instagram @defender_ventures Empire Tuning - Agent |
2nd May 2020 8:57am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1921 |
yes and yes, makes sense to do the furthest!
Lol I'm not in a lazy mood today! But the method is ok isn't it? 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd May 2020 9:11am |
Doddle then.
With diagnostics select pressure bleed, different all all models. Open all bleed nipples and run a line into a jam jar etc... and top up the res. Press bleed. Run it a couple times. Test. If you need to run the same process but individually from furthest to closest. Mega easy. Instagram @defender_ventures Empire Tuning - Agent |
2nd May 2020 9:19am |
Easier than i thought!
Thank you! 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd May 2020 9:31am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
I did mine like this with no issues
sucked old fluid out of reservoir with small pipe, gravity drained filled reservoir with nice new clean fluid used a cheap easi-bleed device bled each caliper in turn until nice new clean fluid came out bled each caliper again just to be sure topped up the fluid happy days DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
2nd May 2020 3:28pm |
Whats in an easy bleed device them?
Looked on halfords and theres a few different ones 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd May 2020 6:41pm |
I used this one, dead simple and worked AOK on mine
https://www.halfords.com/tools/hand-tools/...21141.html DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
2nd May 2020 7:51pm |
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 |
Start with the furthest? I thought you started with the closest and then worked to furthest? That said, does it even make a difference?! +1 on the eazi-bleed kits - less than a tenner from Halfrauds, the one with the container is very useful as it saves it spilling everywhere! Used it on SWMBO's golf today, will do the defender in the next couple of days. |
3rd May 2020 7:20pm |
In my world of all pipes and fluids we work from the closest to the furthest, but it may be different in other worlds?
I don't think it really matters in this instance though. 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
3rd May 2020 8:04pm |
