Home > Maintenance & Modifications > Anyone got the TF fender roof console?
bankz5152
Considering fitting one, could do with a better spot for my CB, the extra storagae would be nice + easily adds a light for the rear.
Anyone got one fitted? How is it? Well made? I am a tad worried itll take a lot of space away!
Post #685818 11th Feb 2018 5:50pm
Crossfit_Pete
United Kingdom 2007 Defender 90 Puma 2.4 CSW Firenze Red
Mine has one fitted but I didn't fit it!
The light is useful as well as the storage Thumbs Up
Post #685828 11th Feb 2018 6:29pm
bankz5152
Ahh good! Stays in place? Doesnt wobble or creak? How big is the storage space? Could you post some pics please Very Happy
Post #685829 11th Feb 2018 6:31pm
Romadog
I have the original Outback roof console which Terrafirma one is based on. Main difference being that Terrafirma usedoriginal interior lamps Thumbs Up Though I have LED Festoon bulbs in mine which makes a difference. I also sprayed mine black and trimmed it to go round my roll cage 'B' hoop.
It doesnt take up too much space. The rear lamp is a bonus Thumbs Up
If you have Mud rails or other versions under your seats then it will be in more view, but not an issue for me.
I fitted mine for the same reason, though I originally bought it for mounting a Tachograph.
Post #685831 11th Feb 2018 6:34pm
Matt110
Re: Anyone got the TF fender roof console?
Hiya, wondering if you ever got one of these as a terrafirma version and could take any side shots of it, looking at romadog's one it does look deeper in section. I'm 6'2 and my brother is 6'7 so trying to figure out how much it drops down.
Also, anyone know if it uses original fixing holes through to the roof reinforcement bar or does it need more holes creating in the headlining?
EDIT: just found an image, but still can't quite tell what it's really like to use if you're tall. Plus there's no measurements i can find anywhere. Have added the image in.
Hopefully final edit......
EDIT:
Turns out most of the information on the entire internet is on the forum. You just end up going full circle Very Happy Very Happy Very Happy
https://www.defender2.net/forum/topic12005-30.html
Post #828756 1st May 2020 8:07am
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Wow, that thing looks good and it's not even expensive... hmmm... could be another Lockdown project. Insta: @thebenjordan4x4
Post #828769 1st May 2020 9:20am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
A friend of mine has one of these in his 110- it doesn't feel particularly well made.
Regards
Chris
Post #828771 1st May 2020 9:27am
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
I also have the Outback version, not the Terrafirma, so hope this helps.
I'm not quite as tall as those asking about the unit, but you never feel it intrudes into your headspace (Puma 110 with two standard front seats).
The Outback unit is quite well made. It uses existing mounting points but yes you do need to trim visors - I did my own and was reasonably happy with the result. It also helps that you rarely look at the trimmed end!
And, my unit is carrying an iCom radio, ie not zero weight, and has never felt like coming loose. Admittedly I don't do a lot of off-road/corrugations (it has done some) but it's just never moved.
Measurements: it's about 240mm @ widest point, and it drops down 110mm deepest.
Finally, a side-view photo, taken from the back seat:
Post #828832 2nd May 2020 2:37am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
No, but I have one of these, somewhat easy to install, once you plan it out, cables etc, it’s out of the way, can’t see it looking in through the window and most people don’t notice it until you point it out.
Post #829098 3rd May 2020 8:04pm
