Home > Maintenance & Modifications > Wheel arch eyebrows |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Pre-Puma Matt Black eyebrow mouldings:
Front RH: RRC3043 Front LH: RRC3044 Rear: RRC3045 Puma Black Plastic Not Painted eyebrow mouldings: Front RH: MRC9378 Front LH: MRC9377 Rear: ALO710010 Idea of supplier options / cost variation here 2005 Td5 | 90 Station Wagon | Tonga Green |
29th Apr 2020 5:23pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1862 |
Thanks, change of plan if they are £50-£100 each
Had seen Terrafirma matt black set of four for £135 |
29th Apr 2020 5:27pm |
There may well be other options (such as the Terrafirma ones you have found), I just did a quick Google on the part numbers 2005 Td5 | 90 Station Wagon | Tonga Green
29th Apr 2020 5:30pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
I would avoid the Britpart ones personally, the shiny set I ordered a few years ago were of a hard and brittle plastic rather than the flexible OEM versions, several have already shattered having been rubbed down trees. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
30th Apr 2020 8:16am |
Thanks
I was hoping for a recommendation to avoid exactly the type of situation you find yourself in |
30th Apr 2020 3:58pm |
