Home > Puma (Tdci) > is this normal?
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
is this normal?
Yesterday while finding suitable earth points for a CB aerial me and my dad noticed this on the diff, is it normal? it feels almost rubbery.
Thanks Jack
Post #82750 31st Jul 2011 11:55am
Grockle
pinion seal as failed 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #82755 31st Jul 2011 1:00pm
Lorryman100
The rubbery stuff is just the excess sealant oozing out from when the diff casing was assembled/repaired and the 10 x nuts were tightened and torqued. However the oil stain isn't normal as Grockle has stated, pinion seal has failed so take it to the dealers for a warranty fix.
Post #82757 31st Jul 2011 1:06pm
Grockle
also whilst your under there, check the wiring harness isn't chaffing against the dif housing Thumbs Up 2.4 90 XS
Post #82758 31st Jul 2011 1:08pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
If out of warranty you can buy the seal for £18 and EP80W-90 oil and have ago yourself. I'm no mechanic and did it out back of my house in an hour'ish. Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #82772 31st Jul 2011 5:24pm
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Hello,
If you change the seal, check the pipe on the axle. It could have mud in it and stop the axle to breathe when it's warm, the pressure can break the seal.
Thumbs Up
Post #82775 31st Jul 2011 5:48pm
Landie Boy
Thanks guys, i have looked and I can't find where the breather comes out in the engine bay. Where should it be?
Thanks Jack
Post #82805 1st Aug 2011 10:16am
MK
It does not go the engine bay. It goes just a meter or so up. Follow the line. Thumbs Up Puma 110" SW
Post #82809 1st Aug 2011 10:42am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
also the breather should go up behind the cover for the the back of the lights, this was the fix land rover cme up with to stop them filling with mud which then lead to water in the fuel, i believe it was negative preasure in the tank drew water through the lock in the filler cap!
Post #82813 1st Aug 2011 11:32am
Landie Boy
I have been looking, and the only pipe I could find goes all the way to the engine bay. I lose it at the bottom where it enters. Crying or Very sad
Jack
Post #82814 1st Aug 2011 11:32am
Apynala
Hello,
Why don't you try to take off the pipe from the axle and put some air into it. First with your breathe, surely not a good taste but you will know if it's free.
Thumbs Up
Post #82823 1st Aug 2011 12:32pm
landy andy
Clean the oil off the diff, with brake cleaner or similar, then see if, and how quick it returns.
Might be the smallest weep and not worth attending to till later.
Andy
Post #82856 1st Aug 2011 7:07pm
Apynala
Andy
You're right, I spent several hours and days trying to stop oil leaking from the transfert box of my first 200tdi. I've finally decided to level oil each 3 or 4 months. Big Cry
It's just a defender. Whistle
Always sick but never dead Mr. Green
Thumbs Up
Post #82882 1st Aug 2011 11:23pm
