Home > Puma (Tdci) > 2012 defender 2.4 tdci fires once and stops
James2020
Hi,
I have a defender 2.4 tdci 110
I put the vehicle in the shed 6 months ago it was running fine.
I have came start it last week and it turns over fires once and then cuts out. After this you have to wait 20 seconds for it to fire again otherwise it just cranks continuous and will not attempt to fire.
I have cleaned all the contacts under the drivers seat.
Bled the fuel system, replaced the crankshaft sensor and battery. Still the same problem.
I read the ECU and no fault codes.
I removed and sent the AS10 unit away to a specialist. He said he can't find anything wrong with it.
I don't know where to look next really. Has anyone else ever had this problem and resolved it.
Any ideas would be much appreciated.
Thanks
Post #827345 24th Apr 2020 10:51am
Martin
Site Admin
Next step is to try bridging the instrument pack pins for the immobiliser link:
https://www.defender2.net/forum/post814212.html#814212  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #827346 24th Apr 2020 10:59am
