Home > Wheels & Tyres > Tyre shopping ...
aevans692
United Kingdom 1998 Defender 110 2.5 Petrol SW Cobar Blue
Tyre shopping ...
Hi all ...
It does seem like the age old question Laughing 235 vs 265
So on my 110 im needing new front tyres , still running grabber TR's in 235 on boost alloys .. I thought that now would be a good time to swap them all out ...
Im running standard height suspension and id like to avoid using spacers , id like to stick with popular sizes as we will be doing some over landing , should I ever need to find replacements on the quick, if in a jam ..
With all that said I think im looking at Toyo or coopers ...
If I decided for the 265's will these fit with little fuss , some people have said they will really rub , others have told me its ok , I don't want to make an expensive mistake ..
is either size better for off road , which is the better option for overloading ? which fairs better in snow and cold climates such as the alps ... ?
I know its prob been done to death but I cant find any more info .. cheers ...
Post #825389 14th Apr 2020 10:47pm
Grouse
I would go 255/85/16, these are larger in diameter and give better off road performance than the 235 or 265’s. Plus they do not rub like the 265’s that they replaced.
If you do a search on here there are loads of threads - I went for Toyo MT’s and am very pleased - I would buy them again
Post #825401 14th Apr 2020 11:34pm
aevans692
I will take a look , thats not a size that I had looked at , is it a less popular option ? will these fit straight on without much fuss
I had been thinking about the toyo MT's .. how have you found them on the road ?
Post #825406 14th Apr 2020 11:45pm
255/85 is good, what I have now. Really pleased. Minor adjustment to steering lock stops and your good to go. You don’t even need spacers if you can live with a little bit less turning circle. WeWillWin🇬🇧🇺🇸
Post #825410 15th Apr 2020 12:03am
Grouse
Noticeably quieter on the road than Cooper STT, very good handling for a Mud Tyre. They fit std LR alloys and Wolfs perfectly. The Speedo runs accurately. They fill the arch better than a std 235 or 265 which looks too small in the large arch of a Defender.
I just left the steering locks - they only rub ever so slightly on full lock - only on the radius arms which doesn’t do any harm - unless you have a Very picky MOT centre - if so just adjust the stops - 5 minute job
Post #825423 15th Apr 2020 7:03am
JOW240725
I run 265x75R16 BFG KO2 and 255x85R16 Toyo MT, both great tyres!
If you're doing any amount of overlanding I'd maybe stick to 235x85R16 as I'd guess these are the most commonly available? 265x75 and 235x85 have pretty much the same diameter so interchangable in an emergency? Someone will probably correct me if this isn't the case? James
Instagram @suffolk_rovers
Post #825588 15th Apr 2020 5:05pm
Bluest
Are there any decent ATs in the 255 size? 2007 110 TDCi Station Wagon XS
Post #825592 15th Apr 2020 5:30pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Agree totally. I put 265/75r16 BFG MT onto boosts without spacers and no adjustments needed.
The 265 was a standard tyre atone time.
And yes they are so close in circumference that you can carry a 235 as a spare for emergencies.
Post #825598 15th Apr 2020 6:14pm
DSC-off
As far as I know there are no AT's in 255/85/16 size. Even MT patterns there are very few options.
If there was a good AT available I'd run them on the 110.
Post #825633 15th Apr 2020 9:31pm
VVS210
+1 for 235/85R16 on the basis of general availability.
Also totally agree with comments on 235/85 & 265/75 as far as size goes, the difference between diameter & rolling circumference when new is no different to a new tyre vs a part worn one. I ran GG AT2 265/75s on my 90, with a 235/85 as a spare, for 16 years & no issues with them rubbing.
Post #825637 15th Apr 2020 9:43pm
Bluest
Shame, same situation here. 2007 110 TDCi Station Wagon XS
Post #825652 15th Apr 2020 10:10pm
Keep badgering BFG about the KO2 and sellers in 255/85/R16.
It worked for the KM3, I was expecting to never see a 255/85 KM3.
So you might find a 255/85 KO2 eventually.
I'm still happy with my 255/85 KM2. Very Happy WeWillWin🇬🇧🇺🇸
Post #825655 15th Apr 2020 10:16pm
Grouse
This is described as a Hybrid AT - Cooper STT MAXX, they were also on Amazon UK but currently unavailable:
https://www.tyres-pneus-online.co.uk/car-t...120-q.html
https://www.amazon.co.uk/Cooper-Discoverer...B00MXNLQEG
https://tiresize.com/tires/Cooper/Discover...-85R16.htm
Post #825701 16th Apr 2020 7:10am
mobilesawmiller
255 85 16" on steel modulars - no spacers needed, just adjust the stops a bit.
Post #825811 16th Apr 2020 3:11pm
Vitesse
I just replaced my front tyres.. Conti Cross Contact AT as fitted from new in 2015. 235/85 R16. 64000 miles.
Very happy with them.....
I booked them up using BlackCircles.com website but the franchised garage I chose simply did it direct and beat the on line price... weird!
£250 in total inc everything Very Happy 2015 90 XS Santorini Black
Post #827208 23rd Apr 2020 3:34pm
