![]() | Home > Puma (Tdci) > Transfer box |
I agree with you,but lets hope it does the fix. 2.4 90 XS
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
This problem was very common on the older version of the LT230 box (Especially the V8s). The output shaft of the gearbox and the input gear of the transfer box can wear excesivly causing a 'clonk' when you let up the clutch. I am supprised they aren't just changing the input gear as it takes about 2 hours to do the whole job.
Glyn |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
That's what I might expect from an older vehicle, but my Puma has been clunking since new, and LR seem to think it's perfectly acceptable. However, I beg to differ!
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2452 ![]() ![]() ![]() |
Hi
I have the clonk since 8000 km. Noticeable when shifting up between 4th to 5th to 6th. I was also told to be normal. My fatherīs 109" had it, but I also was expecting an improve with the LT230Q (Q=quiet). I`m not sure whether is the Tbox or one of the internal sahft of the gearbox. Puma 110" SW ............................................................. Earth first. Other planets later |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
My clunk was fixed by re-fitting the rear diff drive flange with locktight. Not sure if it is a keyed, splined or taper fit but the mechanic told me that fixed the clunk. Puma 110 - gone
Series III 1973 - going strong |
