Home > Maintenance & Modifications > 110 td5 Chassis beam replacement |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Have a look at https://www.defender2.net/forum/topic70049.html
7th Apr 2020 5:26pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6090 |
110 SW middle seat support.
I don't think they can be easily changed with the body work in situe... I'm ready to be proved wrong, but I've read about people cutting them in half and sliding each half in from each side, then either bolting them back together with some straps or welding it. |
7th Apr 2020 5:27pm |
No external body work needs to be removed. See https://www.defender2.net/forum/topic70049.html for details
7th Apr 2020 5:30pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
I bought a galv one with bolt on brackets from YRM
Lift up the 2nd row floor panel, cut the old crossmember out, new one slides in (with a bit of persuasion!) Still a fairly long job, but the easiest way I've found to do them EDIT: As per the above post |
7th Apr 2020 5:34pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 405 |
Perfect, thank you gents. Doesn’t sound too bad a job as we thought. Very useful to know to go to yrm for the new bit.
Thx Douglas |
7th Apr 2020 5:55pm |
Well, no going back now. Easter lock down project.
10th Apr 2020 9:54am |
It came out eventually. Will be on the phone to YRM on Tuesday.
The worst of the rot was almost impossible to see. Might be worth a check next time you are underneath yours. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
11th Apr 2020 2:04pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
I’m reapplying underseal to my tdci and I read your post with interest.
The beam, at least on mine appears to be an open ‘C’ section for most of its length, but directly above the main chassis rails it is boxed in, creating small closed sections. I found small access holes on the underside, both sides of the car that allowed the injection lance inside; I’ve given both sides a good squirt of Dynax S50. Thanks 🙏 2014 Keswick Utility 2.2 |
12th Apr 2020 2:04pm |
Just to finish off this thread, the replacement from YRM is in. Impossible to get in without cutting off the brackets above the trailing arm supports. Don’t know what they were for. Not doing anything on a SW 110. We assume they are for another body variant?
20th Apr 2020 3:33pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 788 |
Hello,
Have just done the same job on our 110 TD5- managed to do ours without cutting those brackets off with a bit of manipulation and jacking about the body- its incredibly tight but just about do-able. How bad was the front face of the rear seatbox- ours was pretty much toast so have replaced it whilst we are on with it. If I had realised how bad the seatbox was beforehand I would have just done that at the time and saved a lot of faff. Chris |
20th Apr 2020 4:01pm |
It was the corrosion on the seatbox that caused me to investigate mine. Hence the repair plates and careful isolation of aluminium from steel during beam replacement. I didn't need to cut off any brackets from my Td5 DCPU to fit the new YRM beam, which was all done from inside the cabin without removing any external bodywork.
20th Apr 2020 4:44pm |
Seat box was alright. Small touch up around bolt holes, but really very localised. Maybe it was the well known LR tolerances. But if defo wasn’t going in without the bracket removal. Not that they are needed anyway. Once we made up our minds to remove them it was a quick job. Should have saved 2 hours of swearing and gashed knuckles.
20th Apr 2020 5:26pm |
