Home > Maintenance & Modifications > TD5 Horn replacement recommendation |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
I recommend the PIAA horns
http://www.piaa.com/store/c/4115-Horns.aspx |
16th Apr 2020 6:52am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Stebel Nautilus compact
16th Apr 2020 8:03am |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 405 |
I think you need one of these......
https://www.kahlenberg.com/model-f-3-chimetone-air-horn.html |
16th Apr 2020 8:13am |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 159 |
I only had 1 fitted which was not impressive!
I bought a pair of FIAAM hi lo horns and added a wire to the other side like the Pumas have. Much louder and better sound. I got mine at Wood Auto, other suppliers are available! |
16th Apr 2020 11:33am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6090 |
The standard horn on my 2015 VW transporter is impressively loud. worth looking for one of those.
16th Apr 2020 5:42pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1172 |
Thanks for the suggestions
Will any 12v horn for a vehicle be compatible & be a case of Plug n Play ? My confidence has been writing cheques that my abilities can't cash for years. |
16th Apr 2020 8:14pm |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
Nothing wrong with another standard one! Definitely plug and play and completely fine.
I had a posh Hella one that failed. My 90 runs twin air horns off of my ARB compressor just because I had a spare solenoid and switch already wired Insta: @thebenjordan4x4 |
17th Apr 2020 8:17am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
A pair of air horns fit nicely behind the NS headlight.
17th Apr 2020 8:41am |
