Home > Technical > Air intake and need an advice on the Natakanenga snorkel |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17541 |
There is a noticeable improvement in engine performance with the Nak intake, and the quality is superb.
11th Apr 2020 3:32pm |
Mariol66 Member Since: 08 Jun 2012 Location: Perpignan Posts: 35 |
i think i will order
14th Apr 2020 7:26am |
I fitted one of these kits recently and recorded some details here, which may help:
https://www.defender2.net/forum/post820692.html#820692 The performance difference in terms of smoothness and flexibility is really noticeable. Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Apr 2020 7:47am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Click image to enlarge You can also build your own. The tightest part is the hose under the bonnet with a 9.5 cm ID. As I drive through the woods I don't like the top sticking out to much so braches get stuck below them. I have a water collection system with a manual valve under the wing. I think the system is effective I get less then 0.1 bar drop in AAP at 4000 rpm in third gear. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
14th Apr 2020 8:13am |
Thank you for these answers. Indeed, building one myself would be much less expensive but I have neither the equipment nor the skills in welding. For these reasons I write this hypothesis.
Great your link, LandRoverAnorak! I allow myself to take your photo to know if according to you, it would be possible to shorten the part between the two red lines, because I have the impression that the head of snorkel is likely to be too high for my Defender. I have a lifting roof and an LED bar which, once the roof is raised, risks touching the snorkel head. Thank you for your opinions. Click image to enlarge |
14th Apr 2020 9:25am |
Yes, you probably could. I guess you'd have to offer it up to see what best suits your setup. Darren
14th Apr 2020 9:34am |
LRA, yours looks marginally taller than mine anyway, perhaps you didn't ram the end on as hard as I did!
The second pic below shows that the cyclonic cleaner does overhang the roof, so there would be a limit to how far down you could move it. Click image to enlarge Click image to enlarge |
14th Apr 2020 10:05am |
Seeing your photos, I tell myself that maybe the height seems identical to mine, knowing that I would use the current Mann + Hummel head again.
14th Apr 2020 10:10am |
Yeah, maybe. It could just be the jaunty angle that my picture was taken at, though. I'll try and take some measurements later. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Apr 2020 10:16am |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Am I being a bit blonde ? But I can’t see a RAI for a TD5 on the overlander site ? Just for the pumas ?
14th Apr 2020 10:36am |
They only seem to list them for Puma's although I can't see why they wouldn't fit a TD5, at first glance. The air box is essentially the same, ISTR? Darren
14th Apr 2020 11:19am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
It can fit just have to run your own pipe work in the engine bay.
My own snorkel 3.5" Click image to enlarge Click image to enlarge Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
14th Apr 2020 11:47am |
Yes Nakatanenga offers a TD5 version (LHD)
https://www.nakatanenga.de/en/vehicle-equi...-td5?c=312 It will be installed on the top of the left wing and from what I have seen on the internet, the air box is modified to make a new entry under the flow meter. I hesitated to take the model for TD4 as you have, because it would not change the location of the snorkel (my cables for the LEDs go through the right). But it would be necessary to build a room for the connection of the heating motor which is not identical to the TD4. As my Defender is an LHD, I have on the side of the snorkel socket the heating block which makes this location particularly inaccessible. Impossible to pass an 80 mm pipe in large modifications. I could pass it over the top of the right wing but there would be, again, a modification of the air intake of the heating block. |
14th Apr 2020 12:55pm |
I was wondering how the TD5 airbox was modified to receive the kit and I found this link where we can better understand the modifications.
http://www.africaland.it/forum/viewtopic.p...p;start=60 |
14th Apr 2020 1:01pm |
