Home > Technical > Air intake and need an advice on the Natakanenga snorkel
Mariol66
France
Good morning all. I have a Defender TD5 from 2003 equipped with a Mantec snorkel. Like some of you, I find that the air intake is poorly optimized, particularly in the inner wing.
I do not want to cut the engine cover to pass a larger hose and connect it to my area box, I am afraid that I will not be able to do clean work.
So I found at Natakanenga a snorkel kit with a diameter of 80 mm (the Mantec must be within 70 mm) which is directly connected to the air box by modifying it. The problem is that it makes me buy a new snorkel and that this kit is fixed on the wing above left of the TD5 (right for the TD5).
I know that on the forum, some have this model, on TD4. My question is, have you noticed an improvement in the performance of your Defender with a larger one (80 mm)? What do you think of the quality of Natakanenga's snorkel?
This makes me buy a new complete snorkel (I could resell the Mantec but hey ...), is the Natakanenga really more efficient?
Thank you for your opinions
Post #824599 11th Apr 2020 2:59pm
There is a noticeable improvement in engine performance with the Nak intake, and the quality is superb.
Post #824602 11th Apr 2020 3:32pm
Mariol66
France
i think i will order Very Happy
Post #825111 14th Apr 2020 7:26am
I fitted one of these kits recently and recorded some details here, which may help:
https://www.defender2.net/forum/post820692.html#820692
The performance difference in terms of smoothness and flexibility is really noticeable.
 Darren
Post #825116 14th Apr 2020 7:47am
roel
You can also build your own. The tightest part is the hose under the bonnet with a 9.5 cm ID.
As I drive through the woods I don't like the top sticking out to much so braches get stuck below them.
I have a water collection system with a manual valve under the wing.
I think the system is effective I get less then 0.1 bar drop in AAP at 4000 rpm in third gear. Roel
2003 90 Td5 (2009-now)
Post #825122 14th Apr 2020 8:13am
Mariol66
France
Thank you for these answers. Indeed, building one myself would be much less expensive but I have neither the equipment nor the skills in welding. For these reasons I write this hypothesis.
Great your link, LandRoverAnorak!
I allow myself to take your photo to know if according to you, it would be possible to shorten the part between the two red lines, because I have the impression that the head of snorkel is likely to be too high for my Defender. I have a lifting roof and an LED bar which, once the roof is raised, risks touching the snorkel head.
Thank you for your opinions.
Post #825144 14th Apr 2020 9:25am
Yes, you probably could. I guess you'd have to offer it up to see what best suits your setup. Darren
Post #825147 14th Apr 2020 9:34am
LRA, yours looks marginally taller than mine anyway, perhaps you didn't ram the end on as hard as I did!
The second pic below shows that the cyclonic cleaner does overhang the roof, so there would be a limit to how far down you could move it.
Post #825153 14th Apr 2020 10:05am
Mariol66
France
Seeing your photos, I tell myself that maybe the height seems identical to mine, knowing that I would use the current Mann + Hummel head again.
Post #825154 14th Apr 2020 10:10am
Yeah, maybe. It could just be the jaunty angle that my picture was taken at, though. I'll try and take some measurements later. Darren
Post #825156 14th Apr 2020 10:16am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Am I being a bit blonde ? But I can’t see a RAI for a TD5 on the overlander site ? Just for the pumas ?
Post #825161 14th Apr 2020 10:36am
They only seem to list them for Puma's although I can't see why they wouldn't fit a TD5, at first glance. The air box is essentially the same, ISTR? Darren
Post #825174 14th Apr 2020 11:19am
bankz5152
It can fit just have to run your own pipe work in the engine bay.
My own snorkel 3.5"
 Instagram @defender_ventures
Empire Tuning - Agent
Post #825187 14th Apr 2020 11:47am
Mariol66
France
Yes Nakatanenga offers a TD5 version (LHD)
https://www.nakatanenga.de/en/vehicle-equi...-td5?c=312
It will be installed on the top of the left wing and from what I have seen on the internet, the air box is modified to make a new entry under the flow meter.
I hesitated to take the model for TD4 as you have, because it would not change the location of the snorkel (my cables for the LEDs go through the right). But it would be necessary to build a room for the connection of the heating motor which is not identical to the TD4.
As my Defender is an LHD, I have on the side of the snorkel socket the heating block which makes this location particularly inaccessible. Impossible to pass an 80 mm pipe in large modifications. I could pass it over the top of the right wing but there would be, again, a modification of the air intake of the heating block.
Post #825210 14th Apr 2020 12:55pm
Mariol66
France
I was wondering how the TD5 airbox was modified to receive the kit and I found this link where we can better understand the modifications.
http://www.africaland.it/forum/viewtopic.p...p;start=60
Post #825214 14th Apr 2020 1:01pm
