Home > Maintenance & Modifications > Washer question
stephan123
Washer question
Recently purchased some new door sills and noticed that the kit came with two different washers. Can anyone shed some light and why this is the case? I have posted a pic below
Post #825000 13th Apr 2020 3:04pm
Balvaig
You have a washer and a spring washer. The spring washer is to stop the fastener from coming loose from vibrations.
You probably have a washer and a spring washer for each fastener. The spring washer goes next to the nut.
Post #825003 13th Apr 2020 3:27pm
stephan123
Many thanks Balvaig! In other words the spring washer is the last thing to go on the screw/bolt before the nut?
Post #825009 13th Apr 2020 4:34pm
Balvaig
Correct. The spring washer is compressed by the nut, thus securing the fastening.
Post #825012 13th Apr 2020 5:10pm
mk1collector
As above, flat washer to the body then spring washer then nut. Ray
My build thread
Post #825040 13th Apr 2020 6:27pm
